Yes, but credit to the platform (or should I say, the culture that surrounds it) for having an incredibly robust aftermarket (probably the best in the world) that can address some of those limitations. Still not ideal, but its far easier to modify a Wrangler for remote travel than it would be many other 4x4s on the market because of the amount of bolt-on options. The aforementioned "good luck getting a bull bar for the New Defender" -- the problem with the Wrangler is there are too many to choose from!
Absolutely right. It is hard to get super-remote in the lower 48 (contiguous U.S.) - and there just aren't that many places where you have to carry extra fuel. In this way, perhaps the U.S. differs from Australia. Here in the U.S. the Wrangler is probably the most popular vehicle for remote travel.
If you want more practical (though not 'legal') payload, you can take your pick from dozens and dozens of aftermarket options - many of which are 'reasonably' priced. Then, all you have to do is pack sensibly. Travel in a Wrangler actually compels one to be a little bit minimalist, which - one might argue - is a healthy approach to time spent in the back-country. As mentioned above, there aren't too many places where you actually need to carry extra fuel, so you can focus on carrying water, and the basics for camping, hiking, or whatever you like to do. In fact, if you are not in the desert, you don't even need to carry much water, as there is usually snow you can melt, or water available that you can run through a filter.
The Wrangler is not the right vehicle for everyone. And it might be right for you at one point in your life, but not at another. I owned a CJ and a JK, but then moved to alternatives that worked better for my circumstances. But I could see myself buying a JL and pairing it with something like a Power Wagon for our two-car household.
Jeep replaced all the aluminum steering boxes in the JL with cast iron ones, and now the JL drives really well on-road. There is a little bit of play in the steering - just like in the Grenadier - which is a consequence of the recirculating ball set-up (same basic design as found in the Grenadier). So Grenadier enthusiasts might want to think twice about knocking the Wrangler for its on-road handling.
Right off the factory floor, the JL Rubicon is phenomenal off-road, and with the "
Recon" package - 35 inch tires, a full-size spare which actually
fits on the back, 4.56 gearing, and a 1.5 inch lift -
all installed and warrantied by the factory, the Rubicon gives a lot of people exactly what they want.
Weighing in at 4,450 pounds, the four-door gas-powered Rubicon is 1,400 pounds lighter than the gas-powered Grenadier; it has a lighter roof, lighter frame, lighter axles, and lighter running gear. Grenadier enthusiasts see the 5,800 pound weight as only a positive thing - and yes, it is built like a tank - but that is not always an advantage. Lighter weight off-road is almost always better for technical driving. Heavier weight - in theory - is better for longevity.
Lastly, you can also tow a tear drop trailer with a Wrangler. Not everyone needs to tow bigger things, and not everyone needs to carry 1,500 pounds or more to go exploring and camping in the back-country.
Got a nail? Get a hammer. Got a screw? Get a screw driver. Right tool for the right purpose. Long live the Wrangler!
