OK, got it, ... clearly not Friday night for youIts at the underside left next to the ODO
I am glad I am not the only one!Euh, Friday night, tired, ... but I don't understand your question, and drunk two glasses of![]()
Hi , thanks for the response’s but next to the ODO I have the range left in the tank ?I am glad I am not the only one!
That's just one of the options you can choose. You can scroll that one. In the display settings you choose what you all want to see in the scroll menu.Hi , thanks for the response’s but next to the ODO I have the range left in the tank ?
Thanks, I’ll give it a go! Sadly mine was delivered with an Italian owners manual….That's just one of the options you can choose. You can scroll that one. In the display settings you choose what you all want to see in the scroll menu.
Just go with the big wheel to the left until you can select it. Then the scroll symbol will come up.
L'italien est fondamentalement français, non?Thanks, I’ll give it a go! Sadly mine was delivered with an Italian owners manual….![]()
As far as I know: NO. I also searched for the function.Does anybody know whether it is possible to set the trip distance (from the last fueling) in one of the selectable fields?
I think it should, but this function is not (yet)active on the screen.Does anybody know whether it is possible to set the trip distance (from the last fueling) in one of the selectable fields?
Thank you. I use it exactly with this way to get the information right now. But it would be nicer to see the trip data on the screen. For example I normally do not need to set the date there as I mostly know what day it is...I think it should, but this function is not (yet)active on the screen.
It’s mentioned in the user manual. Maybe after the software update?
MEDIA AND INFOTAINMENT
VEHICLE FUNCTIONS DEFINITION
Instrument Illumination Set the brightness of the illuminated instruments.
Settings can be set by the user, such as, Drive away locking, Selective Locking, Leaving Home Central Locking System Light Timeout, Remote Lock Feedback, Auto Door Unlock, Follow Me Home and Re-lock Remote
Unlocked Door.
Park Distance Control - Front Deactivation Here the front PDC can be deactivated, resulting in the four front sensors being switched off.
The user can see information, such as, Engine Oil levels and temperatures, AdBlue levels, Tyre Vehicle Information Pressure, Battery, Service Intervals, VIN number, Total Distance Driven, Software (SW) Version
and Active Warning Messages.
Speed Warning Sound An acoustic warning sound will be heard when the vehicle reaches the set speed.
Passenger Airbag Here the Passenger Airbag can be switched off or on.
Daytime Running Light Daytime Running Light can be switched off or on.
Trip Information Shows trip values for TRIP A and TRIP B. They can both be reset individually.
Reset Vehicle Function Settings
Resets all vehicle function settings to the default values, the user will be asked to confirm before resetting.
Acoustic Settings
The 'ACOUSTIC SETTINGS' menu consists of the following options:
