Hope to know Transfer Case directions
Grenadian
7:07 PM
Korea
Hello? I am a Grenadier beginner.
I want to use the center diff lock. but I don't know the direction to move the selector of the transfer case.
Please tell me the five directions, starting from normal, high, high lock, low, and low lock.
Thanks a lot.
I'm a bit confused—are you driving left-hand or right-hand? The photo in your first post looks like a right-hand drive Grenadier, but the one in your second post shows left-hand drive.
Anyway, you can’t switch directly from H/L to L/L. You need to be in Low Range mode first to activate L/L. The selector doesn’t move in a circular pattern.
Correction: You can switch directly between H/L and L/L. The procedure is the same as going from H to L—come to a complete stop and shift to Neutral
Normally, the transfer case lever will be in the "H" position, which means the transfer case is in High unlocked.
If you lift the spring latch under the knob up towards the knob, you will unlock the transfer case lever, and can now move the lever to either the "L" position, or the "H" Lock position.
If you move it to the "L" position (so pull the lever straight down), the transfer case will be in Low Unlocked. If you move the lever horizontally, you'll set the transfer case to the High Locked position.
In either of these two positions, you can then move the lever to the "L" Lock position, which means the transfer case will be Low Locked.
The "Lock" word means the transfer case is in the locked position (either High Locked or Low Locked) - it will spin the driveshaft to the rear diff, and the driveshaft to the front diff.
In order to lock the rear diff, you need to set the vehicle into Offroad Mode via the offroad switch, and then Rear Diff Lock switch, both on the upper panel. Until you do those switches, the diffs will remain unlocked. There are some excellent videos on Youtube by Robert Pepper (L2SFBC) regarding 4WD diff locking concepts and how they affect vehicle traction.
One example of the use of High Locked is for engine braking on downhill stretches of track. I did a trip down the Bridle Track here in Australia, and some sections of the track are steep downhill, so I set the vehicle to Offroad Mode, and engaged High Locked. The result of this was not requiring much brake pedal, effectively just idling the vehicle down the hill slowly slowly.
Wow! Your pictures and descriptions are perfect. In Korea, the driver's seat is on the left. The pictures I attached are screenshots from the user manual. Thank you very much.
Hello, very kind explanation. In Korea, I have to operate the lever with my right hand on the left-hand drive seat. However, the picture in the Korean manual I had was reversed, so it was hard to understand. Now I understand. I received the car on October 23rd. Thank you for your reply.
Well done for trying to explain this, and especially for recommending Robert Pepper's excellent videos.
A couple of corrections …
The word “Lock” means that the Centre Diff is locked. The front and rear driveshafts are always connected to the transfer case, but when the Centre Diff is locked the power is evenly split front to rear. As you would have seen in Robert Pepper's videos, this is important for both traction and safety reasons when off-road.
You don’t have to be in Off-road Mode to lock the rear or front diffs, but you do need to be in Low Range with the Centre Diff Locked.
I can go H/L to L/L or vice versa. Is this bad practice?
Thanks a lot.
That operation is
I thought that was an acceptable practice, and often needed when towing.
That operation is
exactly. presuming if bad the selector wouldn't allow it.
Really? Thanks for letting me know. So, to go from H/L to L/L, do you need to come to a complete stop and shift to Neutral first?
Yes. Hight to Low or Low to High in neutral and I try and change while wheels still rotating (half walling speed or less). Lock to Unlock or Unlock to Locked then can fo it on the move - I tend to be less than 20mph when doing that.
Thanks a lot.
This image is from a right hand drive manual - you have a left hand drive vehicle and operation (lock / unlock) is inverted.
