Heating system is useless
CRH
10:54 AM
United Kingdom
Mine is slow to heat up and max heat is sub par max heat. I just leave it on floor/defrost level 2 in the cold. Dash/floor results in a whistle on level 2, which is unfortunate, as the rear get no flow without the dash, which is idiotic,. That should be floor and dash with flow controlled by the rear seat passengers. My "Queen of noticing anything not right and mentioning it immediately" was quick to note this when she had to use the rear seat.
See my comment above yours
Neither of us was best pleased with heating system when I first got it but perseverance does fix it.
Mine heats up within 5mins and that was after a couple of days at -6c
5:54 AM
Pittsburgh
Mine heats up within 5mins and that was after a couple of days at -6c on floor I get NO air out of the rear vents, which is the biggest
I do see that, and and that's on the service list. The unit sending NO air to the rear unless it's on dash though, seems to be the ducting scheme.
Unless of course, mine is malfunctioning. If changing function on 3 or higher, I can get a flap noise that sounds much like 25yo Zimm playing "double D motorboat" in Reno.
CRH
10:54 AM
United Kingdom
I have had that at one point, even after the bleeding when on full heat auto, I have a video of it but it's to large to add to the site and I'm an idiot when it comes to computer stuff
Mine has seemed to have sorted itself by using it now it's working
Old Salt
5:54 AM
Connecticut, USA
I have been very fortunate with my HVAC system, no issues. Only had the vehicle for 2 months or so with 1200 miles on it (3/24 Build Date Build # 17256). Until recently I was using manual control and found the system temperatures would swing high and low needing constant adjustment. I was not happy with this until I tried the Auto function. Once I changed over to Auto I have not touched the controls since. Maintains an even temperature and warms up rather quickly.
Reactions: CRH
TJ D
2:54 AM
pacific northwest
What steps did you do? What was the delta!?
I made sure that the coolant was topped off, then followed the procedure a couple pages back on this thread. I didn't IR the vents or anything, but over 60 miles and stopping/starting the engine a few times, I couldn't detect any fluctuation in temps in the cabin for the first time. It used to be every time I made a stop somewhere and got back in, I'd have to adjust it, and often on the road it would go along fine for a long time, then suddenly go psycho on me and go up or down 20 degrees or so. Anyway, quite simple to follow the steps. Good luck-hope you have some success as well.
LWA55DAL
4:54 AM
San Antonio, TX, USA
My heat works really well in one setting only. I shut the rear vents. I put it on the second setting where it blows on your feet and front vents at the same time. It blows hot and get the car almost too hot at times
If I change the setting to blow straight out, I lose temperature and it blows warm, not hot.
But the second setting, feet/straight out works great. I have no idea why.
This is exactly my issue. Heat works great in all other mods except position #1.
Korg
6:54 PM
Warrawee NSW, Australia
154 F 67.7 C Inside Central vent
149 F 65 C inside the Side Vent
119 F /87 C Inside Vent for your feet
Above the Central and Side vents 90 -95 F degrees near top of the vents
I was seeing 80 F down in foot well in the general area.
This was short drive from my house down to Durango 's Albertsons and back. about 7 miles there and 7 mile back
I did not have heat all the way up- and it still really warm in the car, @skibum35 I would have Red Noland take a look at your truck if it is now getting hot.
The Vent for your feet, what would help is another vent over by the door for you feet.
Try the test again with the A/C off - I have found that unlike the last 20 cars that I have owned that the Grenadier HVAC works MUCH better for heating with the A/C off and have had no fogging issues so far.
LWA55DAL
4:54 AM
I am referring to “process of elimination”.
Rear vent is blowing hot hot air, while the face is blowing cold air, surely this symptom doesn’t indicate issue with the coolant level. So we can eliminate that as a root cause?
The above issue is what many are observing. Throwing out the “top off coolant” solution doesn’t add value for this kind of issue, no?
You are experiencing the exact same thing I am experiencing. No matter the position - the rear heat is VERY hot, but on setting “1” (face) the heat is marginal. I have to believe that it has something to do with the diverter in the dash either pulling air from the outside. I have not studied the HVAC system layout, but this is the only thing that would make sense.
CRH
10:54 AM
United Kingdom
Mine was exactly the same. The bleeding procedure needed to be done a few times to eventually fix it. It really is just needs bleeding, I know it doesn't make sense, it didn't to me, but it will work if you persevere.
