I'm thinking about picking up a GP Factor table. Has anyone that has installed experienced any rattles?
No rattles - great product.
Awesome! Thanks for your input.No rattles - great product.
Same here no rattles at all.I'm thinking about picking up a GP Factor table. Has anyone that has installed experienced any rattles?
Hi AJ! Just ordered a cubby scratch and dent...couldn't get a response from the chatbot but I figure this would meed our needs! Thanks for showing the scratch/dent stuffIn case you dont see this on our other thread in our vendor area:
Good Morning All,
We have a another batch of Scratch & Dent Ineos Tailgate Tables available in our Scratch and Dent Section on our website. Like before, we do this periodically where we gather parts that may have some imperfections, production small damage, scratches, or demo units that we have, and put them up for a great discount and price. Good Products for those looking for a deal and dont care about a few scratches here and there. All products function properly. You guys are getting first notice of this as they went live 10 min ago. These typically go very fast. Reach out if you have any questions at all. Cheers
Scratch & Dent Products
Scratch and Dent Units, Pre-Production Models, Demo Units that are available for a great discounted price. All products work as they should and have been verified prior to shipping and listing in this section. All unit sales are final.gp-factor.com
I had the same problem. Different materials react differently to temperature changes. The gap between the wooden cutting board, the metal surface, and the frame will vary from summer to winter.For people asking about ratlles, the unit itself has zero rattles or noises.
Now the cutting board is another story. I had the truck out in the rough last weekend and that poor board got slammed back and forth as the truck was rocking side to side. It's not a deal breaker, but it did get a little annoying.
After a week of trying to figure out how to secure it (because I don't want to take it in and out), I decided to not secure it, but silence it. I put a small strip of adhesive insulation at the back edges of the board on either side. Took it out today and no more banging.
This is some crappy window insulation I had in my garage and it works great, but I had several inches of the weather stripping that came with the table left over. I wish I hadn't thrown that away because it was a lot nicer than this.
Simple irritation, simple fix. Would still 100% recommend this table.
I recently installed the table and it is incredibly well made and love it. I also noticed the cutting board can move about a bit and rattle so I applied a couple of rectangular pieces of foam insulation with a sticky butyl backing on the underside of the stainless steel shelf and when you slide the cutting board in the foam takes up the space and holds it snuggly in place. The foam is about 1/8” thick material.For people asking about ratlles, the unit itself has zero rattles or noises.
I like that. It's a more elegant solution than mine. I may have to steal your idea. Thanks for sharing.I recently installed the table and it is incredibly well made and love it. I also noticed the cutting board can move about a bit and rattle so I applied a couple of rectangular pieces of foam insulation with a sticky butyl backing on the underside of the stainless steel shelf and when you slide the cutting board in the foam takes up the space and holds it snuggly in place. The foam is about 1/8” thick material.
There is a little bit more resistance to slide the table in and out but that is ideal as the foam firmly holds the cutting board in place not allowing it to move around on its own so no rattles at all. Also, as the foam pieces are discreetly stuck underneath the stainless table you won’t see it so it doesn’t spoil the look of the table at all.
Where did you get foam tape?I recently installed the table and it is incredibly well made and love it. I also noticed the cutting board can move about a bit and rattle so I applied a couple of rectangular pieces of foam insulation with a sticky butyl backing on the underside of the stainless steel shelf and when you slide the cutting board in the foam takes up the space and holds it snuggly in place. The foam is about 1/8” thick material.
I bought it ages ago for another vehicle project as I was insulating the interior of a transmission tunnel after a transfer case swap. I believe I got it at Summit Racing as it comes in sheets. Very handy to have, I’ve used several cuttings from the sheets over the years to quiet down lots of rattles and vibration noises on vehicles.Where did you get foam tape?
Some adhesive strips of velcro loop (not hook) could also serve the same purpose.I recently installed the table and it is incredibly well made and love it. I also noticed the cutting board can move about a bit and rattle so I applied a couple of rectangular pieces of foam insulation with a sticky butyl backing on the underside of the stainless steel shelf and when you slide the cutting board in the foam takes up the space and holds it snuggly in place. The foam is about 1/8” thick material.
