GP Factor Folding Tailgate Table(s) - Standard and Storage Cubby
I was worried about rattles too, but thankfully its completely silent. I'm very happy with it.
I installed this today. Love it.
It's built to house a light in the cubby, and clearly has the opening to hard wire it in (I think). I could stick a rechargeable light there, but has anyone played with piggy backing a light on a hot wire off the harness in the back door?
No rattles (besides the empty folds in my wallet). I use it and the cubby all the time. Easily one of the best ad-ons.
In case you dont see this on our other thread in our vendor area:
Good Morning All,
We have a another batch of Scratch & Dent Ineos Tailgate Tables available in our Scratch and Dent Section on our website. Like before, we do this periodically where we gather parts that may have some imperfections, production small damage, scratches, or demo units that we have, and put them up for a great discount and price. Good Products for those looking for a deal and dont care about a few scratches here and there. All products function properly. You guys are getting first notice of this as they went live 10 min ago. These typically go very fast. Reach out if you have any questions at all. Cheers
Good Morning All,
Hi AJ! Just ordered a cubby scratch and dent...couldn't get a response from the chatbot but I figure this would meed our needs! Thanks for showing the scratch/dent stuff
On a budget so good to know this exists!
For people asking about ratlles, the unit itself has zero rattles or noises.
Now the cutting board is another story. I had the truck out in the rough last weekend and that poor board got slammed back and forth as the truck was rocking side to side. It's not a deal breaker, but it did get a little annoying.
After a week of trying to figure out how to secure it (because I don't want to take it in and out), I decided to not secure it, but silence it. I put a small strip of adhesive insulation at the back edges of the board on either side. Took it out today and no more banging.
This is some crappy window insulation I had in my garage and it works great, but I had several inches of the weather stripping that came with the table left over. I wish I hadn't thrown that away because it was a lot nicer than this.
Simple irritation, simple fix. Would still 100% recommend this table.
I had the same problem. Different materials react differently to temperature changes. The gap between the wooden cutting board, the metal surface, and the frame will vary from summer to winter.
I recently installed the table and it is incredibly well made and love it. I also noticed the cutting board can move about a bit and rattle so I applied a couple of rectangular pieces of foam insulation with a sticky butyl backing on the underside of the stainless steel shelf and when you slide the cutting board in the foam takes up the space and holds it snuggly in place. The foam is about 1/8” thick material.
There is a little bit more resistance to slide the table in and out but that is ideal as the foam firmly holds the cutting board in place not allowing it to move around on its own so no rattles at all. Also, as the foam pieces are discreetly stuck underneath the stainless table you won’t see it so it doesn’t spoil the look of the table at all.
Another thought I had and may try is a modification to use a couple of spring tension latches to hold the cutting board in place. If I can find latches sized correctly and look like ones pictured below it might be worth a shot, assuming the tension they provide is enough to hold the board steady. I think a couple of detailed latches like these will match the exposed mechanical aesthetic of the folding mechanism already on the table.
Also, considering experimenting with some kind of shallow stainless steel tension spring not unlike the ones you find to help hold in window screens as you could fit it down inside one of the tracks the cutting board slides through to help hold it in place.
I like that. It's a more elegant solution than mine. I may have to steal your idea. Thanks for sharing.
Where did you get foam tape?
I bought it ages ago for another vehicle project as I was insulating the interior of a transmission tunnel after a transfer case swap. I believe I got it at Summit Racing as it comes in sheets. Very handy to have, I’ve used several cuttings from the sheets over the years to quiet down lots of rattles and vibration noises on vehicles.
I believe this is the same stuff it comes in 0.125, 0.250 and 0.500 thicknesses and the thinnest sheet is what I use most. It cuts best with heavy duty scissors or a new utility knife blade.
You’ll have to experiment a little with the amount of foam to use so you get the tension right. Too much foam (surface area) and the cutting board is tight requiring it too much force to slide in and out. Too little foam and it won’t hold the board in place. You can also place the foam closer to the center of the table or more out toward the edges where the two tracks are. Being a natural product my cutting board had a slight bow to it so I found two pieces of foam around 1 1/2” wide and 4” tall placed about 3” in from both edges gave me the tension I needed. I hope that makes sense?
Some adhesive strips of velcro loop (not hook) could also serve the same purpose.
