yes, complete front driveshaftIs that price including the 2 CV joints?
yeah, that's just parts, labor, I feel, was ....... anyway, It's on the road again and I love it! now to get the lift springs removed.
that's what I'm thinking. waiting to hear back from Eibach. had to send them pics and measurements.Looking at your pic makes me think the clamp will tear the boot with just a little more droop.
Could happen on non-lifted vehicles as well.
There doesn’t seem to be any room for movement on your prop shaft as it’s at quite an extreme angle already , this before you even go off road. I wonder why this is all coming to light now when Eibach have been prototyping these lift springs for quite a while I guess. And Ineos themselves at Kavango has that safari prototype with raised suspension and 34”tyres I wonder what they have experienced or even changed with drive shafts.that's what I'm thinking. waiting to hear back from Eibach. had to send them pics and measurements.
Question: Was this picture taken while the vehicle was on a lift, i.e. the axles hanging free? Or the vehicle sitting on its wheels? There doesn't seem too much clearance between the clip on the shaft and the collar...yeah, that's just parts, labor, I feel, was ....... anyway, It's on the road again and I love it! now to get the lift springs removed.
on level ground. I also fitted a piece of cardboard between the cross member and the shaft, then marked the clearance between the cv joint inner ring. ~3/8 "(9.5mm). Then , from another suggestion, installed an angle finder app on my phone. results = -9.4 degreesQuestion: Was this picture taken while the vehicle was on a lift, i.e. the axles hanging free? Or the vehicle sitting on its wheels? There doesn't seem too much clearance between the clip on the shaft and the collar...
I'm asking because I discovered today on my vehicle that the metal collar of the boots on my front drive shaft seems to have been treated badly. It's not round any more and has dents.
Just recognized this on a short check before going on a ~800km trip this morning. Can't tell if this was present from the beginning. Pictures follow when I'm back home. Vehicle has no lift and is stock config.
Would it eventually be possible to damage the boot with the axle fully articulated down? And thereby putting a force on the CVs circlip that would make it come out of its seating position?
I also fitted a piece of cardboard between the cross member and the shaft, then marked the clearance between the BOTTOM OF THE cv joint inner ring AND THE SHAFT. ~3/8 "(9.5mm)on level ground. I also fitted a piece of cardboard between the cross member and the shaft, then marked the clearance between the cv joint inner ring. ~3/8 "(9.5mm). Then , from another suggestion, installed an angle finder app on my phone. results = -9.4 degrees
Nice work. The props do look to have very little room left for manoeuvre!Floor Jack and ramps assisted full articulation on a brand new 2024 bone stock unit.
I definitely will forgo any spring lift and shock modifications until the driveshaft questions are thoroughly ironed out.
Hope these pics are helpful
I measured the angle between the driveshaft and pinion on mine with no lift, and it was a bit under 10 degrees. I used the face of the bolts to measure the pinion angle, so not super accurate but close enough. The angle is high because the pinion is pointed down, I assume so that it’s parallel with the transfer case which sits higher at the front. This makes sense for a standard two u-joint shaft, but I wonder why Ineos chose to do this with two CV joints. The angle would be less severe with the pinion pointing up towards the transfer case. My old D2 was like this, but it has a double cardan shaft.
Who wants to go first with a cut and turn on the axle housing?The pinion is pointed down as the axle is rotated backwards in order to keep the caster angles within spec. What really needs to happen to help fight against all these driveshaft issues, especially on lifted vehicles, is a redesign of the entire front axle so the pinion angle is much higher and pointing more directly at the transfer case output flange easing the angle of the entire front driveshaft. To do that will require more engineering work from Carraro and Magna and all sorts of analysis for things like caster angles, change in angles as the axle goes through it’s travel, lubrication concerns for pinion running at a higher angle, etc…
The only way to raise the pinion that high without disturbing caster angles is to reengineer the front axle so the kingpin/steering knuckle angles are greater keeping the caster in spec at the higher pinion angle. No adjustable bushings or fancy control arms will fix this as it’s the hard fixed relationship between the kingpin axis and pinion angle because the axle is one solid manufactured component.
On old Land Rovers you could clock or purchase caster corrected swivel housings that would allow you to change the relationship between caster and pinion angles. It was always a black art to get the front caster right and pinion straight enough so the driveshaft angles were less and would run smoother. The Grenadier has fixed positioned kingpins/steering knuckles so the only way to fix this is for a redesigned front axle engineered for less severe driveline angles with steering knuckles that maintain the caster needed for stable steering. I don’t see that happening so for folks wanting big lifts and huge tires it’s always going to be a compromise between capability and reliability which has always been the case with off-roaders.
In other words run 33" or 34" tires with zero lift or minimal lift using the Euro spec 30mm Eibach springs. If you need even bigger tires then buy a Jeep. The Grenadier was designed as an overland style rig from the start, optimized for moderate terrain over long distances while carrying significant payload. Tires larger than 34" are not needed for this design brief. Conversely a Jeep Wrangler was designed for technical terrain and easy fitment of the 35" and 37" tires that are a necessity for rock crawling. Pick the right tool for the job.The pinion is pointed down as the axle is rotated backwards in order to keep the caster angles within spec. What really needs to happen to help fight against all these driveshaft issues, especially on lifted vehicles, is a redesign of the entire front axle so the pinion angle is much higher and pointing more directly at the transfer case output flange easing the angle of the entire front driveshaft. To do that will require more engineering work from Carraro and Magna and all sorts of analysis for things like caster angles, change in angles as the axle goes through it’s travel, lubrication concerns for pinion running at a higher angle, etc…
Exactly… keep it as close to stock as possible for reliability. A bit larger size tires shouldn’t present a problem if they don’t rub but I don’t think I’d even do the 30mm springs either but that’s just me. Your point is absolutely valid as these vehicles are engineered very well for the parameters they were designed to work within. Beyond stock is always going to be a compromise in reliability and driving quality on the road.In other words run 33" or 34" tires with zero lift or minimal lift using the Euro spec 30mm Eibach springs. If you need even bigger tires then buy a Jeep. The Grenadier was designed as an overland style rig from the start, optimized for moderate terrain over long distances while carrying significant payload. Tires larger than 34" are not needed for this design brief. Conversely a Jeep Wrangler was designed for technical terrain and easy fitment of the 35" and 37" tires that are a necessity for rock crawling. Pick the right tool for the job.
A double/double cardan shaft is very likely stronger, but even with good operating angles (which may not be possible on the Grenadier) they never run as smoothly as a true rzeppa style CV shaft. I have first hand experience as my Jeep Wrangler has a double cardan shaft front and rear and at certain speeds it has proven impossible to completely eliminate harmonic vibrations. Most Jeep owners accept this as a fair trade off given the technical capability on tap. But the Grenadier is much more refined both on and off road and few owers are likely to find the vibrations tolerable.Don’t want to burst any other bubbles but for folks thinking they can solve all this with a fancy double/double cardan u-joint driveshafts the answer is maybe. I’d doubt you be able to get an entire new custom assembly to run as smooth as stock especially at highway speeds considering all the adapters and machining/balancing work required to put it all together. If Ineos thought that design would work across the entire spectrum of what the vehicle was designed for it would already be on the vehicle. You’d be chasing harmonic resonating noises and vibrations forever. But that said, it could prove more robust for more extreme off-road terrain but again there is your compromise.
