I'm too wary of aliens to scan anything.
Agree totally. This service is DEFINITELY NOT STANDARD on any vehicle I’ve ever owned. IF SO IMPORTANT, perhaps the dealer/sales should EMPHASIZE it. I totally get following the suggested service…. I TRIED to do it early. BUT I ultimately take the advice of the dealer/service department. Never a mention…. I could even understand and wouldn’t be upset if they’d own up to their lack of education/sales experience/or any other little innuendo of this new company. But to have a flat out denial of warranty is inexcusable and fortells of the potential fragility of this truck. WHAT ELSE DON’T I know? WHAT ELSE IS A WHOOPS, should have mentioned it. An ethical business would back their product and not create such discontent over 3-4000 miles of service.The obvious upsetting part about this, is, you cannot document your own changes as advertised, and have it count. As such, the catastrophic failure at this mileage, which really cannot happen to any diff sold by anyone, anywhere, other than with a manufacturing issue, isn't being covered if you happen to live remote, which was the whole purpose of the truck.
I try to avoid labeling people with the fanboy tag, but think about this fellas. This guy is not to blame, and the dealer and Ineos knows it. If the diff fluid wasn't changed at 12000, and this used cast gears that needed it, the absolute WORST outlier one should expect at this mileage is pre mature wear and noise. Being that changing consumables (oil, belts, hoses, etc) are set at intervals that statistically guarantee (ideally) NO failures under warranty, even THAT becomes a wild ass stretch to say its due to consumer neglect and therefore shouldn't be covered. This is a horrid outcome and everyone should be on notice. You know what happens to GM ls engines that don't have the oil changed and fail? They swap it. Ford? They require receipts, then they rebuild it. Ford f350 diffs are 30,000 recommended if working at max load. 150k if just a mall cruiser. But if the warranty is active, it's just covered period. I've had guys do stupid shit and ignore service with assigned company trucks, but I have NEVER had a warranty denial in all these years. Blaming this fella for a catastrophic Axle assembly failure at 17000 miles is utterly indefensible bullshit for a manufacturer, and portends deeper issues. He had it in at 75% of the mileage, and if it was THAT critical, he SHOULD have been told to have it done. EVERY time I've had service interval done the manager tried to up sell to the next one just in case. It's what they get paid to do.
All that, and if axle failure is a possibility at 17k without the fluid swap, why the hell did they use these in the first place?
Well I guess I wish I owned tractors before… I’m guessing most people haven’t and don’t inherently know the care required. I’ve owned many trucks with locking differentials…. Not ever required. Educating the client to keep the product working might be a focus Ineos should get on…Background:
In deed, breaking in differential gears is necessary. In the beginning the surfaces are not aligned to each other. Small uneven edges and peaks have remained from the mechanical treatment. That impedes heat transfer between the gears and its teeth. In addition the metal structure is not as dense at that time as after breaking in.
That's why in the beginning you should not tow, require high torque or drive at high speed. Otherwise you get local overheating and the metal structure is not as dense yet as it should be. That supports breaking out of parts. When the gears harmonize the surfaces getting smoother and their surfaces gain more contact, the structure gets more dense and the heat transfer gets better and to the required level. The oil change is needed to get rid of small metal and attrited phosphatic coating parts.
Maybe this guideline wasn't followed and the damage would have come anyway, having done an oil change or not. Of course, when you would have done the missed oil change the damage which (may have) build up would not have been detected, as no one looks at the gears (except bigger metal parts would have been found in the oil) or the oil would have been analyzed. But it gave Ineos the possibility to reject warranty.
You had it into the dealer and told them you had a leak, added oil and had a hum, and they didn’t look into it? That’s BS and if it is as you say then I think it falls on the dealer if the oil change is that necessary. Is it on your receipt anywhere that you were concerned about it?
brought my Trialmaster in at 9000 to Mossey San Diego. I live far away. Told them to look over everything. Towed a trailer at 17000. WELL UNDER specs.... 5500#. The rear differential was leaking I noticed after a 750 mile drive. THE BOLTS WERE LOOSE! I tightened them and added a quart of spec gear oil.
If I am responsible for a 20k bill, believe me, there will be lawyers involved. I don’t want that… but
yea.... that would ah.... yea. No one else can do that either. No one but Ineos. Hm.When you had your 9k service done, did they reset your service reminder?
I never had a service reminder come up on the truck. Never got an email reminder as I have always got from other car/trucks. I think they are good guys that just aren’t organized in the product yet. Unfortunately, I’m the one suffering for it. Mossey dealership says they want to warranty but are getting denied. Suggested I start a ticket/complaint with Ineos… Ineos got back to me saying the dealer denied it.When you had your 9k service done, did they reset your service reminder?
Really makes you think they reset it when they did the oil change. You can't miss the service warning, lovely bong every time you get in.puzzling...
yep… they reset it without doing the service. They own it. There’s your lawsuit fella.Really makes you think they reset it when they did the oil change. You can't miss the service warning, lovely bong every time you get in.
Well, I have called customer service, multiple times.... same answer. "Talk to your dealer". Dealer says we are trying to get it warrantied but FINAL answer is from Ineos... "NO." I have been without my truck for 12 weeks as of this Friday... I got it exactly a year ago...So time to get the lawyers involved. And I am the last guy to want to do that... Very frustrated for sure.yep… they reset it without doing the service. They own it. There’s your lawsuit fella.
Nobody “wants” to do it, but there’s no point in laying around powerless and abused to avoid it. The only people you’re a hero to, are the people screwing you.Well, I have called customer service, multiple times.... same answer. "Talk to your dealer". Dealer says we are trying to get it warrantied but FINAL answer is from Ineos... "NO." I have been without my truck for 12 weeks as of this Friday... I got it exactly a year ago...So time to get the lawyers involved. And I am the last guy to want to do that... Very frustrated for sure.
