NixGuys, it's a 3 minute job to undo the bolt that holds the pedal down. Put the plasma cutter away and just remove bolt, flip the pedal over, and and remove the connector. The single bolt is under the round plastic plug at the base of the pedal.
By the way, the Ultimate9 evcX (model X401) completely eliminates the throttle lag on the diesel. It now takes off in city traffic like my Isuzu 4BDT1 110!
Why did you add this specifically? What is the benefit here? I don’t know much about this.Someone else here suggested the Ultimate9 evcX X401 throttle controller and I installed one a couple of days ago, it definitely works with a wide range of adjustment. This is the step up from the model you listed (EVC401) which would work as well.
Still playing with the settings, this one works from the buttons or connects to a easy to use app via Bluetooth. Relatively easy to install, remove single bolt at base of throttle pedal, remove connector at rear of pedal assembly (would be difficult for the big fingered), insert new control unit and run cable to mini head unit.
I got my unit from 4X4 Mods Australia for a good price and they delivered quickly:
https://www.4x4modsaustralia.com.au...te9-EVC-X-Throttle-Controller-All-BMW/Mini-00
Here is a pic of the control unit, it is tiny (apologies for the dodgy pic)View attachment 7833442
The connector comes off very easily when you press the top & bottom tabs and pull the connector apart. ie. you will struggle if you don't press both tabs together.Nix
Your quote 'And remove the connector'. Did that bit come easy for you? It was a struggle for me. The rest of your post was very accurate and helpful.
Regarding the after effects. Really impressive.
...this is why it is so difficult to remove the connector unless you remove the pedal and can access the 2 tabs on the connectorThe connector comes off very easily when you press the top & bottom tabs and pull the connector apart. ie. you will struggle if you don't press both tabs together.
I have the pro on my diesel. Don’t know if it is exactly the same but I suspect it is. They will tell you for sure if you call them.Hello friends, I have been looking at the pedal box pro, but when I go to select the vehicle only the gasoline grenadier appears, does anyone of you know if the same device works for the Diesel. Thank you
PS: Do you recommend it for diesel?
Thanks Cheshire Cat, I'll talk to them and let you know.I have the pro on my diesel. Don’t know if it is exactly the same but I suspect it is. They will tell you for sure if you call them.
I can only say it is a revelation. Very easy to fit and use. Extremely happy with it.
It only influencers the speed of opening of the throttle. Faster , slower or factory mode (no difference to stock).For those that have this installed, does it save the stock tune as a setting? Also, assuming low range has a separate tune from the factory, im guessing by leaving in stock mode everything operates as normal? Thanks in advance!
You will find there are as many believers as non believers. With a scientific mind you can come to your own conclusions.I succumbed to temptation.... the UltimateX9 it should be arriving early next week.
In Ultimate and launch mode it will take off like an EV. She will enjoy chirping the tyres!My wife just drove the Grenadier for the third time, and hates the flat spot in take off.
