Mine is in the post; same supplier, cheers!I ordered mine at the discount price. The ETC was way cheaper than an engine chip or tune.
Mine is coming today, I will fit it after warranty work done.Mine is in the post; same supplier, cheers!
Please post a petrol reportMine is in the post; same supplier, cheers!
In due course as well as the fullness of time , I shall!Please post a petrol report![]()
Will find a hill and give it a go in reverse. Can’t say to date that I ever noticed any issues in reverse but not really exposed to that situation.Hi @Cheshire cat
#2 would win me over. That hesitation to move off quickly again after stopping is tedious. Not sure if it is diesel specific or if the transmission ECU is involved because sometimes there appears to be a lag while 1st gear is selected.
Have you noticed any difference in reverse? Reversing up my shallow incline driveway is weird and especially if I have my camper attached. In reverse the trans feels like it has a high stall torque converter. A lot more revs to get a response. It might be deliberate tuning to increase the starting torque in reverse gear. Quite noticeable.
I can’t see how but for the best technical explanation, contact one of the manufacturers producing them.So would fitment of a throttle controller affect Ineos warranty like say a tune or remap would?
Asking for a friend.
From one sourceSo would fitment of a throttle controller affect Ineos warranty like say a tune or remap would?
Probably not, unless INEOS can prove it caused the problem. But I will install mine after the warranty work is done, to stop even the suggestion.So would fitment of a throttle controller affect Ineos warranty like say a tune or remap would?
Start with Eco Mode and it should allow you to customise from their. Eco Mode dials down throttle response, even with a lead foot.I'm going more for the dampened response under certain conditions ; the stock petrol Grenadier has plenty of get up and go .
That's the plan. I'm on a small hilly acreage so can experiement with and without the van.Start with Eco Mode and it should allow you to customise from their. Eco Mode dials down throttle response, even with a lead foot.
Aye but the petrol one goes OK!For me, it"s just that first 5 seconds or so after take off. To get anything remotely considered smooth, you either have to take off like your great grandma would, or punch it in the guts. anything in between and it lurches away in first but then wants to get to 5th / 6th gear as soon as it can like it has to be in 4th before 40km/h, 5th before 50km/hr etc. once it's away then it drives well in traffic.
Exactly the same experience for me. I found that use of a small screwdriver helped me pry the plug off as I pressed the locking tabs. Not easy.Received my unit. Getting the factory plug off is the biggest frigging PITA! They installed this and then built the vehicle around it. Have a look for yourself!
No doubt there is a short angled factory tool ( same ends as fuse pulling pliers which I nearly took my grinder to) but without the special tool you may end up in the same gnashing teeth frame of mind I was in.
Anyway, never give up.
We've driven down to our holiday home and in Ultimate mode it is perkier.
Later I'll test other modes.
I managed to get the bottom tab just off the socket then tried various tools to hold/ pry the top tab down. Once I could see with my dental mirror both were down with no tools I gave it a pry with finger and screwdriver.Exactly the same experience for me. I found that use of a small screwdriver helped me pry the plug off as I pressed the locking tabs. Not easy.
My experience exactly. I had to walk away, take a cup of coffee, and then think "What would the dealer do while charging me over £100.00 per hour"? That motivated me enough to accomplish the task.I managed to get the bottom tab just off the socket then tried various tools to hold/ pry the top tab down. Once I could see with my dental mirror both were down with no tools I gave it a pry with finger and screwdriver.
I had to go inside and unpack my troubled mental state for a couple of minutes!
Oh and I contemplated dremelling the plastic overlying the plug for a better view
