Differential Pinion seals weeping?
Asnes
5:00 PM
Windermere, FL, USA
I was doing routine inspection at 7k miles yesterday and noticed that both front and rear pinion seals at the differential seem to be weeping / sweating a little. No oil on the ground and discoloration around the seal is somewhat minor.
Is this normal?
Is this normal?
I had the same with no visible drip and oil levels remained fine many thousands of km. seals have been replaced now though.
Makes sense. Not concerned. I’d like to get a free diff gear oil change front/rear out of a warrantee claim :)
Think my front diff has this weeping problem.
7200 miles in, 2023 model. 50/50 onroad offroad.
33" tyres, no lift.
Have ordered some TRIPLE QX EP 80W90 for the front diff as that's what the dealer (Harwoods Portsmouth) exchanged the factory fill for at it's first service last September. Will get under and remove the fill plug and hope it takes very little to top up!!!
Anyone have photos of the front diff fill (and presume a drain) plug(s)?
Can't get under mine properly today and the bash plate is making visible access difficult.
Presume I just fill the bugger up until spills out as per usual?
So after having the dealer replace the front differential pinion seals mine appears to be weeping again!
Ffs!
I was under the car today changing the engine oil and saw and smelt the difference fluid in the same lower spot.
Have ragged it clean and will check it frequently and speak to the dealer again.
Note I have fitted neutral raised breathers into the engine bay for both front and rear diffs. Rear one not had a problem. Second time weeping with the front. Once with OEM breather and now again after replacing it with 8mm pipe. Makes me think this is not a pressure problem.
No water crossings or deep puddles since dealer replaced it 3 weeks back.
  • Angry
Reactions: CRH
You don't just fill the bugger up the oil has to be below the fill hole by an amount there is a too task dealer of procedure,
Tks. Have since seen the chat on that matter. What a pain, if only we had the workshop manual from the beginning......!
Have you guys written down part numbers for the seals? The invoices may have them.
Unfort I do not as all under warranty.
Dealer might be able to supply.
Picture of my front Diff below, cleaned off and checked the level and alls good until the dealer can replace the seal.
Thanks to @ECrider for what tool to purchase to remove the fill port. Will buy some appropriate oil from Opie Oils.
A footnote, this is the first real anomaly I have experiences since ownership except for the initial software update.
