General Check engine light - fuel level sensor P0461
birdogs
6:26 PM
Tallahassee, FL, USA
You have to get the fuel tank level down, drive it for 30 minutes than clear the code.
I can do it with almost all my OBD tools. I keep a OBD Link CX in the truck. It works
Thanks - will get the fuel tank low and light going to refill and then try clearing the code again. I was in the middle of a road trip when happened so had to refill with the code still, but will try again before the next fill up.
IslandFalconer
7:26 PM
Prince Edward Island, Canada
Just needs to be down a touch. Word of warning sometimes you reset it and the Check engine light is cleared but not the Triangle in the telltale, you need to let the vehicle go to sleep to clear it.
