General Check engine light - fuel level sensor P0461
You have to get the fuel tank level down, drive it for 30 minutes than clear the code.
I can do it with almost all my OBD tools. I keep a OBD Link CX in the truck. It works
Thanks - will get the fuel tank low and light going to refill and then try clearing the code again. I was in the middle of a road trip when happened so had to refill with the code still, but will try again before the next fill up.
Just needs to be down a touch. Word of warning sometimes you reset it and the Check engine light is cleared but not the Triangle in the telltale, you need to let the vehicle go to sleep to clear it.
What was the outcome of this ? So far I’m on the same route. Obd2 reader confirmed fuel and triggered power steering. Says it cleared but when vehicle turned on, still throwing error.
Attempted to reclear and let vehicle sit now…
I was able to borrow another code reader which cleared the code -- but, reading @IslandFalconer this now, it may have been just enough drive time between attempts that the fuel level had dropped enough. I have not seen the code since --- it's only happened the one time.
I got this error and the CEL yesterday after a fill up. First time in the 2,500 miles that I have had the car. I think I did top off but don't actually remember. This morning I cleared the code in under a minute with an old code reader I had laying around. The reader is a Actron CP9125 and will now live in the car if needed again.
I haven't read through this entire thread, but the fuel level software update was released several weeks ago. Dealerships will load it t for you if you have a CEL.
I took delivery on line October 2. 1165 miles - stopped to fill up. Did not overfill it but check engine light on after fill up. That’s one of the reasons I bought this thing - my BMW M5 throwing check engine light and limp mode almost every time I drive it now so this is incredibly disappointing. Tried to clear the fault with my BluDriver OBD plug in but no luck.
I got the CEL on my 2nd tank after buying and got the software fix on Oct. 30th. A couple of days ago I put in 10 gallons or so (because it was cold) which took it up to 3/4 tank and the CEL came on when I started it. Checked the code. P0461. Again. Seriously?
Check with your dealer - I had mine in for service last week and they detected the fuel level plausibility stored code* which they said gives them (IA) permission to perform TSB 003368.
*I never had an error code displayed or CEL.
I purchased the Obdlink Mx+ through Amazon (to use across the full range of makes our extended family drives) and it worked to clear the gas code Now if it could just prevent the seemingly endless codes that pop up while driving from the forward sensors.... I have never seen this many false codes from a vehicle.
Yup, there are so many warnings and bongs that it is distracting and dangerous. I rented a trailer today to haul some debris from the windstorm/fire we had here in Pasadena and the trailer had a faulty tail light. Every time I taped the brakes the Christmas tree of faults lit up and it bonged continuously. One simple warning light telling me there is a trailer light fault would be sufficient.
I've filled up my tank 5 or 6 times but yesterday after filling up the check engine light came on. My dealer, Elliot Bay, informed me this has happened to a couple people when overfilling the gas tank. I did not overfill it, just let the gas pump shut off automatically. The code is P0461, which is for the fuel level sensor circuit. I was able to get the fault cleared at O'Reilly's since the dealer is over an hour away. I also noticed that when the check engine light is on the cruse control does not work. As soon as I got the fault cleared the cruise controls works again.
Not sure if all new cars have a fuel level sensor but I didn't have one in my LR4, that I'm aware of, so first time having to be concerned about overfilling.
Robert: this just happened to me today, cruise control not working also, how did O’Reilly’s clear the fault, do they have access to the vehicle’s software? I had my local BMW repair shop change my oil, because my dealer is 5 hours away, and they could not update the oil change warning, dealer would not help them. Thank you Jim
The engine codes can be cleared by a generic OBD2 scanner... The service indicator is not a simple code reset, thus a generic tool can't do that.
There's nothing an Ineos dealer can do to "help" another place reset the service indicator
I cleared the CEL with the OBDLink MX+ earlier today…🤞🏻🤞🏻 it stays that way.
Thank you very much.
