I never used my cruise control, until today! Tried it on a 45mph stretch and it seems to work pretty well.I’m not sure if the range calculator is affected. I’ve only had the CEL happen once and once cleared things seemed normal. One crappy thing-if a CEL is on, cruise control will not work. It’s annoying. I understand why they do that but it’s annoying nonetheless.
I'm with @AwbunBradon -- the AD410 did not clear the PO461 code. But it DID trigger a power steering failure warning! Turned the truck off, let it sit, restarted, no power steering warning. ...Thanks for posting. It worked for me!
Worked for me too. Thanks for the recommendation!!I bought an Innova 5010 from O'Reilly Auto Parts for $38 and it will clear the code. I'm 2+ hours from the dealer so it was cheaper than a tank of gas.
What is ACC mode?Got the CEL after a fill up yesterday. I did not top it off. I was able to clear the code with my Autel code reader. Once I cleared the code everything returned to normal. I had the vehicle in ACC mode when I cleared the code. Typically that is where it needs to be to clear codes on most vehicles.
Key on, engine not running. ACCessory mode.What is ACC mode?
Got the code in the morning, ordered the cheapest scanner on Amazon and had it delivered and cleared by 5pm:
Ancel AD310 Classic Enhanced Universal OBD II Scanner
Best $21 I’ve spent.
Just had our CEL come on immediately after fueling up. The only difference this time was I filled up half way through a tank not completely empty. Hoping when the OBD2 scanner arrives tomorrow I can confirm that’s the issue and clear it.I am super excited about this forum. My light came on just after getting gas so I felt pretty comfortable that’s what it was from.
No changes in driving or anything like that. I searched check engine light and came upon this thread.
Having never done a diagnostic test like this, I went ahead and ordered from Amazon last night. The reader came today and with no knowledge and how this works, I was able to plug it in and go through the system in a matter of minutes and the light is now off, and it was definitely a fuel code.
I agree, the best $21 spent. I’m gonna keep this in the center cubby box cause I’m sure it’ll happen again, but the peace of mind of driving around with that dumb light on is priceless.
Yeah as soon as you have a CEL/MIL no cruiseJust had our CEL come on immediately after fueling up. The only difference this time was I filled up half way through a tank not completely empty. Hoping when the OBD2 scanner arrives tomorrow I can confirm that’s the issue and clear it.
Happened to notice our cruise control doesn’t work right now with the CEL on.
