Work light on roof grab bar
Stedi cube light on my custom bracket. I needed to stay fully below the rack and still clear the door. Stainless bracket mounts to both top & bottom of the rack, rock solid and gets the job done.
I bought a Stedi harness, shortened it, replaced a DT with a DTP, then it was plug and play.
Is this a front runner load bar? May I ask where you get the bracket for it?
That is the rear of the factory Rhino rack. I made the bracket myself, from 3mm stainless sheet from McMaster. The fasteners are also genuine Rhino purchased as a replacement parts kit.
Hey guys. Thought I would ad my thoughts.
I have seen these brackets
These would clamp onto the grab bar allowing mounting of pretty much whatever light you want. Get two for a light bar. My preference would be the stedi micro dual touch.
They are dual colour. Dimmable. Can have the master switch in roof switch, then have the lights turning on at the light so you don't have to reach inside every time you want it on.
That looks like a great light, but not yet available through the US store.
