WolfBox - As A New Vendor, Offering 20% Off Discount!
Clark Kent
6:28 AM
Toowoomba QLD, Australia
I refer to my wolfbox as the “Strap-On” 😂…as I used the straps to mount to the existing mirror. Works well for me but I am considering mounting the mirror so that it is just above the infotainment system which would still allow me use of the OEM rearview mirror while giving a better field of view for the forward camera (no interference from the ADAS box).
Quickly back on topic: Wolfbox sell a centre console base bracket that might be adaptable to one of the dash mounting rail systems. It won't be tall enough to sit behind the infotainment screen but would sit nicely on the space above the telltale panel.
ANNML
1:28 PM
Phoenix, AZ, USA
I kind of like your idea of where to mount, hmmm, wonder if anyone has done this! Stop giving me ideas and options lol!
I’ve never had a dashcam but I assume they’re mounted, duh, to the dash — so it’s more supplemental in nature bc you leave mirror in place and have both. So your idea is more like that correct?
AngusMacG
3:28 PM
Massachusetts, USA
Correct. I spoke with the service mgr. at Curry about my idea. He indicated that it would be very easy to mount it there and we both agreed that it would be best to use some arm mount that is screwed/bolted to the enclosure behind the infotainment screen. This would definitely make the Wolf box as an accessory rather than a primary piece of equipment. He also indicated that it might be possible to wire under the dash to hide the wires.
scottyboy436
8:28 PM
scotland
Been looking at andyt post about where to wire up the the wolfbox, what he says is completely different to the manual I have downloaded for my car , anyone able to help?
Aaron B
12:28 PM
Seattle, WA, USA
AndyT,
Question for you on the fuse box for the front facing camera install. Which exact slots did you decide on? It’s hard to tell from your image. Also did you have to do any other modifications other than just plugging in the two pigtails facing right?
Thanks!
WolfBox
Supporting Vendor
4:28 AM
LA
Update: The 18% discount is back and covers all the products on the site. The codes are the same. Please read the first post.
Drive with safety and fun 🍻 🌄
2:28 PM
Houston, TX, USA
You can use this location only for the the yellow wire. use a fuse tap 7.5 on the left. This fuse location are the fuses that are always on.
Black wire to any metal surface for ground.
Red wire is with the ignition. Get a wire 5' go to the back seat behind the driver, lift seat and look at the fuse panel on the left. I used the first row. use a fuse tap. I put my fuse tap on a fuse 30, my tap fuse on the top will be a 15. Now take that wire bring it under the seat frame at the corner of the fuse area. Both doors passanger and front driver have sills at the bottom, pull up and they will come off. They will snap back in very easily. Using a plastic spatula or trim tool push the wire under the flooring all the way to under thae dash. Connect this wire to the red and you will be in business. If you have carpeting you will need to get your wire under it. It may be a bit more work.
Airleader
9:28 PM
Black Forest, Germany
Please some pictures asap. Thx.
holdmybeer
12:28 PM
Vancouver, BC, Canada
It looks like that base might be reversible (whether or not Wolfbox intended that) which might give you the angle and height needed to mount behind the touchscreen with another plate or rail. i.e. Reverse the hinge if the pin or set screws cooperate. Just speculating.
