Mine constantly thinks it's leaning left by 4 degrees according to off-road settings.
Strange, mine is also drunk!Mine constantly thinks it's leaning left by 4 degrees according to off-road settings.
Do you mean the scuff panel assembly?and another fault/malfunction (unfortunately I can't find a suitable subforum);
I have quite a lot of water in the body cavity in front of or under the boot cover behind the seal after driving in the rain and after the car wash - does anyone know the problem? The boot itself is dry. There is no drain in this cavity, so can't be normal....
Keep a spare key fob battery in your wallet. I met a mechanic in Namibia who diagnosed a flat key fob battery at a safari camp‘s two Defender that had been out of action for months.I’ve got a new warning code.. it nice to see something new and after seeing it on one trip yesterday, it’s not reappeared...!
I’ve not checked but I’m guessing they are cr32s.. it’s good advice and the alert has not repeated since. I believe the Gren can be fully operational with just the key, but I may be wrong.Keep a spare key fob battery in your wallet. I met a mechanic in Namibia who diagnosed a flat key fob battery at a safari camp‘s two Defender that had been out of action for months.
my own defender had a flat key fob battery that caused the alarm to go off every time I tried to unlock the vehicle![]()
That would be good news re operational without the key.I’ve not checked but I’m guessing they are cr32s.. it’s good advice and the alert has not repeated since. I believe the Gren can be fully operational with just the key, but I may be wrong.
Mine too, 6 degrees, waiting on a fix, just needs calibration I suspectStrange, mine is also drunk!
It's because of the shitty weather.New one today. Anyone else had a flux capacitor fail?View attachment 7822150
Is the time correct?New one today. Anyone else had a flux capacitor fail?View attachment 7822150
So you are the first with a dual zone heating. You only have to find out how it works.HI! FIRST HEATING PROBLEM.
All ghost gremlins until today made no problems. One alarm ended after half an hour, an never came back. BUT YESTERDAY:
I wanted to heat the car (for the first time) - but warm air ONLY came on the driver side, on the other side (right side) it stayed cold.
HAS ANYONE HAD THIS AT HIS INEOS, TOO?
Mines the exact same!Mine constantly thinks it's leaning left by 4 degrees according to off-road settings.
try driving in same direction but on the other side of the road... when safe to do soMines the exact same!
Same here!Mine constantly thinks it's leaning left by 4 degrees according to off-road settings.
Tried that - drive on the wrong side to see if its a camber issue. Takes some of it away but still shows roll to the left even when I can feel a physical roll to the right.try driving in same direction but on the other side of the road... when safe to do so... I watched the Left-Right tilt change with the road camber earlier tonight depending on whether I was in the left or right lane (2 lanes each way on "B" grade "highway" ... well what else does one do to relieve the boredom ...?
( I am most impressed with the spread of the headlights on high beam!
I can confirm that irrespective of the key fob battery, you can open, lock and drive the Gren using just the key. On mine, unlocking with the key, unlocks all the doors, whereas using the fob only does the drivers door.That would be good news re operational without the key.
I assume a second press opens the others, and you can program it to open all at once via the infotainment screen?,..... whereas using the fob only does the drivers door.
There’s a software issue on mine that doesn’t allow me to tweak the locks. when you open the drivers door, it’s supposed to unlock them all. However on mine, when you open the passenger door, it opens them all. A double click on the fob does unlock all doors as you say.I assume a second press opens the others, and you can program it to open all at once via the infotainment screen?
Mine is at 5 degrees when on a level surfaceSame here!
I didn't know that...it seems counter-intuitive to what the purpose of driver door only opening is supposed to be about?There’s a software issue on mine that doesn’t allow me to tweak the locks. when you open the drivers door, it’s supposed to unlock them all.
