Where is the front auxiliary power point?
rovie
12:21 PM
Pat-Ard
Global Grenadier #00520
6:21 PM
So, I went down to my car and opened the hood, after a one minute search I found both of the power points. Just on the driver side (LHS) in front of the water refill...
Challenge accepted and went to search the one in the footwell on the right. Found this, too. But this one is really tidy fixed. On the drivers side it failed because I couldn't get the floor lose...
But now the next question how's the polarity for the DTP? Black wire in 1 and lilac in 2 or the other way?
Finally I found this sticker under the hood. Where ist the 2nd hood rod Position?
grnamin
11:21 AM
Texas, USA
Please confirm the following...
Thank you very much in advance.
Jean Mercier
GG#920
6:21 PM
Sint-Martens-Latem, Belgium
ericge
12:21 PM
I wonder if it would be more convenient to add a Deutsche plug connector to the end of the under-bonnet connections.
Of course. If you're going to have a power outlet, at least make it useable. I resent the $200 it cost me to find the outlet and fit a Deutsch socket.
TheDocAUS
4:21 AM
Eromanga
It costs a lot more to run your own cabling, fuses, switches, plugs. etc than using what INEOS provides. I just bought some DTP plugs and a crimper and I only need so use them once to cover the cost - verse having an auto electrician do it.
I will install two UHFs and some work lights saving myself lots of money. I say thank you INEOS.
Pat-Ard
6:21 PM
Hooorray!!! I managed to find the power point in the LHD drivers footwell.
In my case it was a little higher up.
Next I'll order some Deutsch DTP plugs and will fit all power points with plugs...
Thanks to everyone here on the forum for the help.
