- Local time
- 12:48 AM
- Joined
- May 19, 2022
- Messages
- 2,266
Here you go
Need a photo?
Need a photo?
Very nice! Thank you, Rovie!Here you go
If you compare with my second picture in this thread https://www.theineosforum.com/threads/aux-sockets.12412566/page-2#post-1333201829 you will see that this is indeed rightPlease confirm the following...View attachment 7837494View attachment 7837495
Thank you very much in advance.
Of course. If you're going to have a power outlet, at least make it useable. I resent the $200 it cost me to find the outlet and fit a Deutsch socket.I wonder if it would be more convenient to add a Deutsche plug connector to the end of the under-bonnet connections.
It costs a lot more to run your own cabling, fuses, switches, plugs. etc than using what INEOS provides. I just bought some DTP plugs and a crimper and I only need so use them once to cover the cost - verse having an auto electrician do it.Of course. If you're going to have a power outlet, at least make it useable. I resent the $200 it cost me to find the outlet and fit a Deutsch socket.
Hi @rovie the lilac wire connects to Pin 1 and the black to Pin 2, correct?Here you go
Speaking of which, is the polarity universal even with vendors or do you have to watch out for it?Hi @rovie the lilac wire connects to Pin 1 and the black to Pin 2, correct?
where did you get this graphics from? i'm new around and interested to finding more like this.So you only have the 10A outlet on the right hand side as you are looking into the engine bay
They came from a dealer pocket guide back in late 2022where did you get this graphics from? i'm new around and interested to finding more like this.
thank you. i found it under:They came from a dealer pocket guide back in late 2022
There may be a link on here somewhere so just search pocket guide.
I downloaded a copy from a UK website in December 2022 so it also may not be 100% current
