Devil horn's, add at lease 1000 hp and 2000 torque (y)
But only on Halloween night....:eek:
Blahahahahaha, I thought that’s what they were…..man I’m glad I’m not up in Canada as all hallows’ eve is just upon us and that bad boy is about to wake up!!!!!!!!!😎
Btw, I don’t even want to know who you made a deal with and for what to get that kind of power!!!!!! 🤪
So are you saying that he must have gone to the crossroads, the same place the great blues musician Robert Johnston went, and the rest of the 27 crowd.
I am waaayyyy past 27 thankfully, but I am a huge blues/jazz fan (actually all music, even opera/country/etc; there is only one style I won’t listen to & classic rock is my go to)….anyway, in response to your first part of the above post:
What is this method you speak of?
When the warning is displaying, press the end button on the LH stalk once to highlight it, then a second time which acknowledges it, and then select one of the options on the main screen, vis home, Offroad, audio, phone, settings. Which cancels it. It will stay off until the ignition is started again
I’m fitting a Bluetti charger 1 which is an alternator charger for my power station. Question, what is the quickest way to get that battery plastic surround off so I can access the busbar and negative earth next to the battery? How do I get these nuts off without having to take the seats out? My star attachment can’t fit under the bars which run across. Thanks
Quickest way is with a pair of tin snips. And it's the quickest way should you need to go back there chasing a fuse.
Btw, I have not used or tested this yet as waiting for my message to appear. So saved this on my phone for when it happens as I’m 4 hours one way from the dealer. Good luck. 👍
@Dual Grenny Guy : I ammended and improved "my" procedure, as explained by @Eric in this post here:
Therefore, you should probably take new screenshots, the "new" procedure is much easier. I use it every time I drive, as my dealer wasn't able to reset the warning after my two last services!
And thanks for quoting me :cool:
A Dremel with a cutting disc and a vacuum cleaner to catch the bits when you are cutting the plastic.
Gotta love the Comet! The scientific reason that Comet A3 became visible was to check out all of our Grenadiers! BTW the comet APPROVES of all of our Grennies! :)
Ah I already knew that one. I thought he’d found a permanent solution.
There is an updated version, but nothing permanent yet. I think we all are waiting for the software update that fixes these little annoyances. 👍
