Dual Grenny Guy
7:37 AM
Louisiana, USA
So are you saying that he must have gone to the crossroads, the same place the great blues musician Robert Johnston went, and the rest of the 27 crowd.
I am waaayyyy past 27 thankfully, but I am a huge blues/jazz fan (actually all music, even opera/country/etc; there is only one style I won’t listen to & classic rock is my go to)….anyway, in response to your first part of the above post:
Eric
1:37 PM
Scotland
What is this method you speak of?
When the warning is displaying, press the end button on the LH stalk once to highlight it, then a second time which acknowledges it, and then select one of the options on the main screen, vis home, Offroad, audio, phone, settings. Which cancels it. It will stay off until the ignition is started again
Skydance
1:37 PM
MANCHESTER
I’m fitting a Bluetti charger 1 which is an alternator charger for my power station. Question, what is the quickest way to get that battery plastic surround off so I can access the busbar and negative earth next to the battery? How do I get these nuts off without having to take the seats out? My star attachment can’t fit under the bars which run across. Thanks
11:37 PM
Quickest way is with a pair of tin snips. And it's the quickest way should you need to go back there chasing a fuse.
Jean Mercier
GG#920
2:37 PM
Sint-Martens-Latem, Belgium
Btw, I have not used or tested this yet as waiting for my message to appear. So saved this on my phone for when it happens as I’m 4 hours one way from the dealer. Good luck. 👍
@Dual Grenny Guy : I ammended and improved "my" procedure, as explained by @Eric in this post here:
Therefore, you should probably take new screenshots, the "new" procedure is much easier. I use it every time I drive, as my dealer wasn't able to reset the warning after my two last services!
And thanks for quoting me :cool:
