Oh that's still very far away from me😅 I live in the far north of Luxembourg on the Belgian border. As I said, if you would drive through, let me know😃 I wish you a good night and don't forget to pay tomorrow🤣
I didn’t know that there was a „far north“ of Luxembourg.
Nice i have the same in black (y)
I am home after my visit to Hambach.
Today I had an error I didn't notice in the past I guess, at least I don't remember having had it: Airbag System Error.
I am proud of it :devilish:
But it disappeared after restarting the car. 😭
I will post my findings of Hambach in a separate thread,
[EDITED] @Eric.S. : I drove through the far South of Luxemburg ;)
I said that because Luxembourg is such a huge country and you understand it better🤣 Except my translation is not very good😅
@Jean Mercier I don't like the far south so much now and is avoided by me🤣
It will RETURN👻👻👻
Got mine in the optional colour dirt, suits it really well
If I may inquire,
The bike rack that is attached, is that the Ineos available one or another (different) brand?
If I may inquire,
In Oz most adaptors use the 2 inch square. So The hinge is a Yakima swing back (2") and the bike rack is just a Costco ebike rack (2"). Was really neverous because the Yakima bolt hole is fairly deep in, a standard ball wouldn't fit but the bike stuff did
I had my drawers fitted today. Custom made to fit out of aluminium, with adjustable drawer dividers and the top made out of phonelic board. Fridge slide fitted as well.
Total weight is circa 60kgs
I’m pleased with them
Nice work, the only issue I can see is access to the fridge unless you're quite tall. Drop slides are popular for this kind of set-up but they weigh 60kg alone.
Thanks for the feedback. I’m quite tall, so not an issue for me, but the fridge slide tilts forward to ease access if needed. I’ll put the fridge in and then post another picture.
Ahh, ok. I was going to suggest a tilt slide. If you can partition your fridge it will help stuff not slide to the front.
Out of curiosity could you tell is what the height and depth dimensions of the drawers please, and how deep the fridge slide is please.
No problem. My design principles were that I wanted to keep the top of the fridge in line with the top of the rear seat back when placed on top of the drawers. This resulted in the top of the drawers being the same height as the left side inner trim “shoulder”. I chose to fit the drawer top flush to internal trims on each side. The downside of this decision is that I have relocated the jack into one of my new drawers. I think it was a pretty poor place to install the jack originally, so no big deal really.
I left the boot floor mat in place and secured the drawers into the captive nuts already fitted for the tie down rails. In theory, you could remove the boot floor mat and gain an extra 20mm, but in practice, the bottom of each drawer will then hit the plastic trim in the boot floor. So that trim would also have to be removed and replace with something else.
Dimensions of each drawer ………
Internal length is 800mm
Internal width is 500mm
and internal depth is 250mm
Finally, the fridge slide is 625mm long (to fit a Dometic CX35).
I think there is a further 90mm usable between the top of the seat back and the front edge of the drawers. I think 715mm is your realistic limit for the length of fridge, once you allow for the fridge slide as well.
I’ve spent an hour earlier this evening trying to see what will fit where. I think I’m almost there, but will have another look again tomorrow before I commit to screwing down tie down points. I may re-locate and re-use the original tie down rails, not decided yet.
I think the bottom line is …. there’s not that much space to play with, so you need to take your time to maximise space use. My chairs are now touching the luggage net I added into the roof space, so I’ve not got too much left to play with.
Still waiting for my rear door table and cargo barrier from Ineos to finish it off (and the mats, and the official tow bar, and the replacement bolts that dropped off two months ago) but that’s another story.
Any questions, please let me know
Have you had to allow for that in the drawer lengths?
I hope I have. Table doesn’t seem to stick out much more than the door handle and I’ve enough room to get my hand in comfortably, so I hope to be OK
Fingers crossed!
