I made a storage box for my spare wheel. Mostly out of stuff I had lying around.
Made for purpose in Australia
I picked up my Grenadier after having it's 45k klms service and 4 warranty claims sorted out. In order of alerting the agent of the issues.
1st was the indicator on the highrise air intake which had fallen off due to bad quality 3D printed housing...looks like a proper moulded piece now.
2nd was the side steps that had started to show surface rust after gravel had chipped the paint off the cross member in the middle of the steps...I am in the process of sourcing protection to stop it from going that way again.
3rd was the oil leak from the high pressure turbo oil supply line...replaced
4th was the diesel soot leak, failure of the EGR Exhaust Gas Recirculation...replaced EGR assembly.
All is good again.
I was also informed that the agent is waiting on parts for two recalls...
1st is the door buttons/mechanism
2nd is strangely the diesel engine cover that apparently fails in the environment in which I live...the underneath material fails and breaks down.
It is interesting to live in sub tropical conditions and see what effects body sweat can do to the arm rest surface material on the door.
I have a pic attached where you can see the change in tone where my elbow sits while driving. That also has changed the surface tension going from a shiney surface to a dull flat soft finish. I have cleaned it with all but the kitchen sink, no change. The agent said they will watch the outcome.
Meanwhile I have repurposed a facewasher, a chopstick and foam rubber. Sow the facewasher together inside both end hems...the chopstick slides into one of the hems and is pushed into the space between the armrest and the rubberized felt window seal, when the window is closed after insertion it holds the chopstick in place and the foam rubber just slides in between and adds more comfort for my boney elbow 💪
You should just buy a kevlar tactical gauntlet for your next mission.
How are the small cupholders holding up? Tinnies still fit?
All is good again.
Would leather treatments help or is it fake leather?
Salts get into leather from your skin, I try and wax the leather on an annual basis (but often fail)
Not much proper leather on modern cars; Grenadier is no exception.
The armreast is plastic, made from Ineos chemicals.
