Made for purpose in Australia
I picked up my Grenadier after having it's 45k klms service and 4 warranty claims sorted out. In order of alerting the agent of the issues.
1st was the indicator on the highrise air intake which had fallen off due to bad quality 3D printed housing...looks like a proper moulded piece now.
2nd was the side steps that had started to show surface rust after gravel had chipped the paint off the cross member in the middle of the steps...I am in the process of sourcing protection to stop it from going that way again.
3rd was the oil leak from the high pressure turbo oil supply line...replaced
4th was the diesel soot leak, failure of the EGR Exhaust Gas Recirculation...replaced EGR assembly.
All is good again.
I was also informed that the agent is waiting on parts for two recalls...
1st is the door buttons/mechanism
2nd is strangely the diesel engine cover that apparently fails in the environment in which I live...the underneath material fails and breaks down.
It is interesting to live in sub tropical conditions and see what effects body sweat can do to the arm rest surface material on the door.
I have a pic attached where you can see the change in tone where my elbow sits while driving. That also has changed the surface tension going from a shiney surface to a dull flat soft finish. I have cleaned it with all but the kitchen sink, no change. The agent said they will watch the outcome.
Meanwhile I have repurposed a facewasher, a chopstick and foam rubber. Sow the facewasher together inside both end hems...the chopstick slides into one of the hems and is pushed into the space between the armrest and the rubberized felt window seal, when the window is closed after insertion it holds the chopstick in place and the foam rubber just slides in between and adds more comfort for my boney elbow 💪
You should just buy a kevlar tactical gauntlet for your next mission.
How are the small cupholders holding up? Tinnies still fit?
  • Haha
Reactions: Max
All is good again.
Would leather treatments help or is it fake leather?
Salts get into leather from your skin, I try and wax the leather on an annual basis (but often fail)
Reactions: Max
Not much proper leather on modern cars; Grenadier is no exception.
The armreast is plastic, made from Ineos chemicals.
It is the same material for all Grenadiers I would imagine. Just too much sweat, my wife and I walk quite a bit and with the Queensland humidity it pours out (y)
Had to deal with this:
Only 16,000km on it. 3 screws close together and can’t be repaired apparently. Agggh. You’d have to think some prick has been scattering them on the road ffs.
And there’s no KO2’s in a 265/70-17 around at the moment, so it’s a KO3 on the back as a spare.
$465 down the drain.
And Donald’s taking about unbalanced trade and pricing - you can probably get the same tyre in the US for a hundred bucks. 😭
I hate when I hear that...me personally would plug the holes and keep an eye on it as my spare. If it fails, keep the spare on the truck and check for a second handy...does your agent have any?...bloody nuisance 🤞
Disregard if you've already pulled the trigger on the KO3, but there is 5 new K02s going on the Aus FB group for $1000. Sunshine Coast.
Take the one you want and sell the rest?
Daughter mixed a little too much GID epoxy for a school project, so I thought i’d fill in the hollowed out back of the Grenadier USA rear handle😂😂
I have no idea if any of it will even show when the handle is mounted but it was the closest thing that came to mind when she said I have less than 5min before it starts to harden😁😁
