In anticipation of the imminent deliveries, what did you do with your Grenadier this weekend?
Tell the community and share the love, and pictures, lots of pictures.
This thread will remain locked until the first member tells me they have taken delivery.
I took my 4 year old grandson for his first ride in a Grenadier. Wouldn’t you know it we saw another one while we driving. He said ha Granpa there’s your car. 😁
I bought a set as stickers on Etsy. The company was from salt lake City. Both the hood and the v behind the ladder on the door was in the set. They also shipped the rest of the letters in white but I didn't care for that.
I put ppf film on top of the decal.
Would you want me to look up the website site of the seller?
I'm on a road trip with the Grenadier in northern Nevada but should be home tomorrow and can send you a link.
As much as I love making my friends my Google b1tch, I wouldn’t do that to you. Knowing it’s on Etsy is all I need. Thanks.
The plan was to add a couple USB ports on the center sides of the front footwells that were tied into Int 2 switch. I never realized it was one overlapping panel after the next. It was like each one had that 1 screw hidden below a panel above it. I have to admit though, they certainly designed these to be taken apart.
Got the two wired but using double sided tape to make sure I like the location before drilling into the panels. Would like to move them up somewhere by the circles, but can't figure out how to get that panel off.
Doing what I can to prevent problems; the cracked windscreen thread threw up this idea ; every bit helps and it seems quite a few chips happen at the lower edge.
Cut the red backing tape in the middle, peel off and apply the LHS first, then move to the other side and repeat.
Or the opposite if you're left handed!
Trim piece
Did a Tazzie and stuck some rubber around the edges. Perhaps not the neatest of jobs but I'm normally inside looking out!
I also stuck some Denso 16" wiperblades on the front as recommended by another forum member. Apologies forgot who. Not tested them yet as miraculously we have no rain at the moment. Motor does seem to have to work a bit more.
My daughter will now be happier - charging ports installed on both sides. Did my best to make a wiring harness to plug into "Int 2" so things can be swapped out without clipping wires. Next job will be the footwell lights but already put bare wires into this harness to wire them up.
Not sure How I feel about these yet. Originally going for Owl Talon White, but they are out of stock indefinitely - Did not want black, and gun metal may have been a better look. Installed them leaving the H&R spacers on. No Rubbing. ET +38 AND 33mm spacers each side. 1 rim came bent, so spare will be replaced soon.
View attachment 7891655View attachment 7891656View attachment 7891657View attachment 7891658View attachment 7891659View attachment 7891660View attachment 7891661View attachment 7891662View attachment 7891663View attachment 7891664
Why use spacers? The rim offset of +38mm is already 17mm less than the factory wheels and spacers are definitely not needed to provide clearance for the tires as shown.
Had spacers from the 55 offset Steelies and wanted to see how it looks. Wasn’t about clearance, originally was for filling out wheel well from tucked in look. It doesn’t look like old mini truck kick outs.
I did the thing that makes me a valid participant in this thread today:
And before you ask, no news on software updates. Also doesn't look like they've changed the front driveshaft on the MY25s.
So the 25 still has the ADAS bong set to on as default?
Got around to finishing the install of my Tougher seat covers, and dash mat. Quality bit of kit, and Staffy and Chihuahua approved! Ordered directly from Tougher in SA as I wanted the 2 tone covers to be similar to the cloth seat colours.
Latest posts
