Website Broken
The bad screen happens on my work pc (Chrome or MS edge, both controlled by my employer) but not on my home pc running Chrome.
Clueless as to why.
it happens on all my browsers, work computer and personal computer (both windows 11).
It doesn't happen on my android phone unless i select desktop mode in chrome.
My android tablet doesn't look that great either btw.
Forced dark mode on iOS, Oops! Error if I try to switch it. It’s a non-issue - I can still get my Grenadier content…
Will the structure of this website return to what it was just as of a few weeks ago?
Click on the circular icon next to the lightning bolt at the top right hand side of the page. You can select system, light or dark modes.
The structure hasn’t changed, do you mean the ‘look of the site’ if so then it will remain very similar to as it is now.
The software update was carried out by the hosting service that also handles the backend software, basically I have to roll with it and make it as good as I can.
Doesn't work here dark mode won't work and the formatting is all over the place btw im Mac
These are the steps I took to get it to work on my Apple devices:
-Scroll to the very bottom of the page. On the lower left corner, you should see “Forum Main Themes”
- Click on that and choose: “Use Default Style”
- Then go back down to the very bottom again and click on the icon to the right of the “Forum Main Themes”…should be a crescent moon, gear, or 50/50 black/white circle icon.
- Selecting the crescent should put you back into dark mode🤙🏻🤙🏻
thanks for the tip but it doesn't work
Ah!! A balmy summer's morning, first coffee for the day...... and the website on my laptop is back to normal!
Life is great!! 🥳
Thank you Stu!!👍
Can you give a screenshot? the site is run and maintained from Macs.
Now I’m assuming you have tried clearing the cache/history and reloading the site.
Make sure you’re using main theme which you can select from the very bottom of the page it’s in a menu activated by clicking on the text next to the paint brush icon.
If it’s set to default theme it can glitch out.
