Click on the circular icon next to the lightning bolt at the top right hand side of the page. You can select system, light or dark modes.Forced dark mode on iOS, Oops! Error if I try to switch it. It’s a non-issue - I can still get my Grenadier content…
The structure hasn’t changed, do you mean the ‘look of the site’ if so then it will remain very similar to as it is now.Will the structure of this website return to what it was just as of a few weeks ago?
It broken on my phone. Don’t waste your time on this though.Click on the circular icon next to the lightning bolt at the top right hand side of the page. You can select system, light or dark modes.
Try clearing the history and logging back in. It worked for me.
These are the steps I took to get it to work on my Apple devices:Doesn't work here dark mode won't work and the formatting is all over the place btw im Mac
thanks for the tip but it doesn't workThese are the steps I took to get it to work on my Apple devices:
-Scroll to the very bottom of the page. On the lower left corner, you should see “Forum Main Themes”
- Click on that and choose: “Use Default Style”
- Then go back down to the very bottom again and click on the icon to the right of the “Forum Main Themes”…should be a crescent moon, gear, or 50/50 black/white circle icon.
- Selecting the crescent should put you back into dark mode![]()
Can you give a screenshot? the site is run and maintained from Macs.Doesn't work here dark mode won't work and the formatting is all over the place btw im Mac
This solved all my issues!Make sure you’re using main theme which you can select from the very bottom of the page it’s in a menu activated by clicking on the text next to the paint brush icon.
If it’s set to default theme it can glitch out.
