Water Leaking from overhead console
2:31 PM
Reno, NV, USA
Anybody else heard of this happening?
Rained last night. Get in this morning and as soon as the vehicle moved water came dripping out of the driver side interior light switch on the overhead console.
Checked the aux power cover in the center of the roof or whatever that plastic cap is and it appears to be on tight. Im guess it’s getting in from the Safari windows somehow, but they’re not leaking into the cab. So I assume it’s leaking around the seal and going into the cavity between the roof and the ceiling.
Haven’t removed the console yet but that’s next on the list.
The cover in the center of the front portion of the roof is your GPS/Sirius antenna
Or here
I think it would help us all not to DIY. Otherwise, INEOS will not acknowledge the issue.
Here is a discussion of leaks I believe you are describing ... https://www.theineosforum.com/threads/leaking-multiple-areas.12414402/
Yep probably the exact same thing.
if my dealership was local Id report it but they’re not, they’re in Pasadena and Im in Reno. Was originally told my dealership would be Kuhn Automotive in the Bay Area but they never got opened. And they told me originally if there were problems they’d come get it. I don’t think Rusnak would do that.
For what it's worth, it would be a closer drive for you to head to Lyle Pearson in Boise... And not have to deal with SoCal traffic at that point.
Or, wait until later this year when, inevitably, another NorCal dealer will open
It's the safari windows, the water gets everywhere, just get the seals redone at the dealer
My Grenadier just last night showed droplets on the dash under the camera/rearview mirror for the first time after 9 months. Bummed for sure...
I had the same issue. Turns out mine was leaking through the antenna. You should have the dealer check the safari windows and antenna.
Where is your antenna/ariel located. UK models don't have an external one, why have they put them on in USA, is it necessary for some reason?
I didn't realize it was a USA thing. Th antenna is located on the front center part of the roof.
Well like you I have learnt something today, I never spotted that the USA models have a roof mounted antenna. Something we don’t get in the UK.
I didn’t get the safari windows as I just knew they would be a problem. I always think back to Landrover Discovery sunroofs that always used to leak.
The annoying thing is, back in the 80’s when sunroofs became a must have in the UK, it became a big business retrofitting them in cars and they were near on identical to the Ineos ones, just pop up and pop out if needed. The bizarre thing is the ones I had never leaked !! Go figure.
Exactly my experience with the Discovery 2. I sealed the roofs myself back then. I didn't want to repeat that effort.
