Petrol/Gas US Oil for B58 Engines
What Oil are you guys using (weight/ brand) for the diffs and T-case?
I'm at 1100 miles on my Gren. Plan on doing an engine oil service soon- reading this thread is making me want to tackle the diffs and transfer case as well!
The transfer case is the easiest to change, given the ease of access. Used valvoline synthetic 75w-90, with the flexible container, to more easily pour into the fill hole.
my transfer case fluid at the 800miles mark had a LOT of metal flakes. The oil was almost milky for the initial few seconds of flow.
Reactions: S52
I’d be careful and double check the levels of the transfer case a few times after a refill. With a cooler in the circuit it will be hard to know for certain the true level unless you measured exactly what you took out and put the same back in.
For example, would draining a cold transfer case produce less/more fluid than a hot one? What cooling cycle/mode was the transfer case in when drained? Does that even matter? Is the fill plug even a legitimate measurement point for the transfer case like on a differential or does the manual call for putting in a specified amount which has no relationship to the fill port?
I would have to think there is a specific drain/refill procedure the dealer performs which involves hooking their diagnostic system up to the vehicle and triggering a circulation pump, assuming it’s an electrical one. Would love to see Ineos service documents on this procedure anyone have a friend at a dealership who can take a screen capture of their software?
Liqui Moly TopTec 6600 if what I have used for the break-in oil change and the 2nd one at 7k miles
Here is the excerpt from Liqui Moly. I had trouble finding an oil that met BMW LL-17FE+ but the Liqui Moly was on Amazon.
  • The BMW Longlife-17 FE+ approval is intended specifically to reduce the risk of LSPI. LSPI stands for low speed pre-ignition and means that the mixture ignites spontaneously in the combustion chamber at low speeds before the ignition spark.
For the diffs I used Valvoline Full Synthetic 75-90. I have not done the T-case yet, but plan to use the same. Likely going to do that this weekend.
Yes - that’s the same on the diffs. You want to do it cold as the oil will expand if it’s hot, but honestly - by the time you drain and fill - it won’t be that hot and your fine.
I personally overfill until it wants to keep coming out of the fill hole and plug it.
Diffs really don’t get hot. You’re not talking much difference on the oil level. I’m still not sold on multiple changes. My 3/4 ton work truck that I only use for towing has 227k miles and no diff issues. Changed twice at 100k mile intervals.
Apparently you don’t tow anything - they get very hot towing and there is a reason there is an entire market dedicated to diff covers and temp sensors. I completely disagree with changing diffs at 100k if you don’t want issues but your truck - your call. I’ll do what I want to do and you can do the same, but I sure as hell wouldn’t tow on a routine basis and do diffs at 100k.
Happy trails!
Happy trails!
That truck has 226k miles and was used for a company towing goosenecks for delivery lol. Average temp is about 185-190 meanwhile the breakdown is over 300F. Diff fluid is like boat lower unit oil and I've seen many 200k+ trucks that never have it changed. That oil isn't running through an engine dealing with combustion and compression. Unless you drown it in water that synthetic isn't breaking down. GM doesn't even list a change interval on the axels and says 100k for heavy usage. So it gets it every 100k. Runs and drives like a champ. If you want to go argue with GM feel free. My Land Rover didn't do it that often either and 12k intervals is an absolute joke on these diffs.
Well Mossey Houston is charging $860 for an oil change and both dif service. Outrageous.
If it makes you feel better I did mine at valvoline just to see what the fuss is about at 17k miles. They absolutely didn't need it. Total cost for all three was $240
Keep in mind that some of us change fluids out of habit. Coming from an old LR fleet (down to two thankfully) that see off road use, when there is wading involved I typically change fluids on axle, swivels and t-case every month.
The first diff service is at 12k but the second is not until 60k. Still sooner than the 100k you reference, but thankfully it isn't every 12k. I'm assuming that first 12k is to remove any swarf from the building process and maybe the fluid has some breakin additives or something.
If one were to install a clutch differential I'd consider a cooling cover, but, otherwise, these diffs should never produce enough heat to damage anything. If they are, there's something wrong with them. I picked up the AO Iron covers. Since he was at it and charged 300/ea, he should have cast some fins into them, but it isn't a deal breaker.
What diff covers are those???
They are on the Agile off-road site. Expensive for what they are, as a banks set that has cooling fins and air direction for my f350 are about 2/3 as much, but, I want the diff bomb proofed as we’re never gonna see easily available parts for these units.
This is a great thread. Now let me throw something new in the mix. What if you're using mostly ethanol free gas, what does that mean for oil type? Cause i have access in Texas to ethanol free gas and use that mostly in all my cars.
I have 2k miles on my Grenadier. Since the engine was warmed up when I got gas today, I ran the engine oil check. It said it was OK for on-road and to add 500mL for Off-road. I'm planning an off-road trip for spring break so I assume that means I should go ahead and add some oil. My question is: what oil should I use? Do I need to go over to the BMW dealer and get a bottle of factory oil? Who makes the factory oil? Castrol? As long as it meets the specs does it even matter what oil I use? Thanks.
You got it mostly right. I was a powertrain engineer at Ford during the transition from 5W--30 to 5W-20. The reason for the change was to help meet CAFE (Corporate Average Fuel Economy) standards. The lighter weight oil results in lower frictional drag on the rotating components which results in a small increase in fuel economy. While engine wear was extensively test and found to me acceptable, the final go/no go decision came down to engine sealing. The ability of the engine seals and gaskets to keep the lighter weight oil on the inside of the engine. The biggest concern being the crank seals. Any retroactive change in oil recommendations would be restricted to engines that were able to pass all testing with no modifications. That said it was the universal opinion of any of the engineers that I worked with that our personal vehicles would be switched to 5W-30 at the first oil change. I have to roll my eyes every time I get an oil change at the various arguments I get as to why, "I really should use the manufacturers recommended oil."
Interesting post I found somewhere else. I can tell you my IG has been loving QS Euro 5w40. HTHS of 3.88, runs super smooth. Might switch it up soon to Pennzoil Platinum Euro L that's LL04 cert and even though a 5w30 it's a heavy 5w30 with at least a HTHS of 3.5. I suggest very similar to the Quaker state.
Not much really. The ethanol free gas tends to be on lower octane. I'm experimenting now with regular gas to see what % drop I see in mpg. I do notice a slight performance decrease but in the end the numbers will tell.
