Transfer case oil change procedure
C-Mack
10:12 AM
Mendon, Utah, USA
Without the actual service technical documents or a prescribed procedure I’d hold off on a transfer case oil change (or at least have the dealer do it). Judging by the different quantities of oil being drained out by various folks it suggests the oil cooler is playing a factor and there is probably a very specific procedure to make sure the cooler is drained and the exact right amount is put back in the entire system.
If for example, you catch the thermostat open and the entire system drains out but you can only get sufficient back in to fill the transfer case you’d be short the amount of oil that is supposed to be held in the cooling circuit. With no way to get the remaining amount in the fill port without it overflowing back out you’d be running the entire system low of oil. I don’t think you can rely on the fill port as a confirmation the level is correct like you can on most differentials.
I bet my left lug nut there is a fill procedure which requires certain temperature parameters be met and/or some kind of recirculating pump needs to be triggered electronically, or the transfer case needs to be ran with the vehicle on a lift stationary to circulate the oil in the cooler circuit before a final top up.
I’d would also like to be able to do the transfer case maintenance myself but would want to see actual service procedures beforehand. It would be an expensive mistake to make running the transfer case low even though you had serviced it with the best of intentions.
S52
9:12 AM
USA
Does anyone know what size socket is needed for the transfer case fill/drain and the differential fill/drain?
They look like allen head bolts?
LWA55DAL
11:12 AM
San Antonio, TX, USA
So talked to the tech in San Antonio and apparently the max fill on the diffs is supposed to be a couple MM’s below the top of the fill hole. So you aren’t supposed to fill it all the way up or it is over filled.
10:12 AM
Denver, Co
Couple mms bElow. That’s the dumbest design. Doubt the transfer case specifies that level of precision
4:12 AM
Need to get that tech to spill the service document. Is it 2mm , 2.1, 1.9 - we need to know.
10:12 AM
Denver, Co
Then it should also prescribe the exact angle the vehicle rests at. Do the techs use a level, to determine how thr transfer case is situated?
Couple mm.. lol. The goddamn grenadier is not a spacecraft.. pretty sure the tech was intentionally fking with him, to make the diy service sound daunting
LWA55DAL
11:12 AM
He was dead serious. He said they have a tool, again like an Allen wrench, that you are supposed to insert in to the fill hole to measure the level.
I filled mine like every other vehicle I have ever owned and it was coming out of the diff breather.
Tom109
12:12 PM
Seriously pulling your chain!
I hope you mean "fill hole" and not breather!
Tom109
12:12 PM
Picked my Gren up last Friday from its first Service. I asked about the t-case change and they confirmed it is like any other mechanical - open fill hole, drain, refill until oil appears in the fill hole.
10:12 AM
Denver, Co
But for the IG, there is a cooling system for the transfer case. Did you ask how they performed a full bleed as well? This is highly nonstandard
