Would be great to rewire one of the roof outlets so a solar cell can connect to it....As published several times by some clever people here in the forum, see the attachment from the CTEK User Manual.
I connected the 250se to the alternator, not to a solar panel.
@Lollo050968 when the car is running are both batteries being charged by the alternator ?
Do both batteries see the charging voltage (14V) ?
What happens when the smart alternator turns off (charging voltage not present with engine running) ?
That’s my understanding too. The smartpass seems to allow both to be charged via the alternatorYes, both are charged.
At first the starter battery “provide” , than when there’s a difference of xx% (~10%), the auxiliary start to provide too, balance both batteries on a equal level
Adding to the confusion, I hadI have created a table to understand the percentage readings of the China monitors.
It is (still) completely fuzzy, because I don't have enough values. But you can already see how much the percentages depend on interpretation. I have taken the volt/DoD figures from the pictures posted here. The columns name the respective sources.
The "INEOS" column is the most complete. I used only the "discharge" values, since the "charge" situations seem to show only what the generator delivers, but not the actual battery voltage. This becomes obvious if you see that the voltage values for charging and discharging are completely different at the same DoD percentage.
But also the discharge values are to be taken with caution, because discharging with 8 amps or with 16 amps results in different voltages (although I consider the difference for such large batteries negligible within this current range).
But as an approximation, it is already clear that the INEOS curve is not linear and, to my understanding, seems to be defined with some thought behind it.
I personally trust the INEOS values the most.
If we collect some more readings here I will add them to the diagram.
For the INEOS readings, only report 'discharge' readings with no more than around 15 Amps.
If diesel, likely due to glow plug/pre-heater and/or fuel pump priming.- massive voltage drop by turning key
The 250SE will charge at 20A whenever the engine is running whereas the Smartpass is dependant on the smart alternator and can only charge the service battery to around 75-80%.Would installation of the CTEK 250 also help loading faster when driving or simply add additional load options with plugging, solar power,…?
That's very unlikely.adding the battery monitors: can they have an impact on the system?
Which kind of reading is this? From the car's display or from your monitor?Adding to the confusion, I had
- 12,5 V being 77%
- 12,0 V being 76% as well as 67%
and as it jumps up to 14,x V as soon as you start the car, confirms your statement of it being not worth following that route…
High draw vs low draw?I'm about to install a 2channel dashcam. "Plan A" is to connect the "constant 12v" lead to the auxiliary/service battery positive ( via a busbar I found in my 'might-be-useful-one-day- treasure -box") and the ignition lead on either heated seat fuse #121 (which is spare because I don't have heated seats).
What I don't "quite" understand is why the Smartpass 120s diagram shows a car fridge attached to the so-called "out" terminal , while other devices such as radios and external lights etc are wired to the positive of the auxiliary battery. Should I attach the busbar to the "out" terminal instead?
The Smartpass will kill the load when it reaches 11.5V whereas using the battery direct will drop it to dead flat (which can damage the battery). Ctek are saying you might want the UHF to still work below 11.5V as you might see it as a higher priority (emegencies) than say a fridge. I'd go to the sevice battery if the dashcam has a time out setting or voltage cutoff. My Blackvue 750 dual can be set to switch off after so many hours via the App, which I do.What I don't "quite" understand is why the Smartpass 120s diagram shows a car fridge attached to the so-called "out" terminal , while other devices such as radios and external lights etc are wired to the positive of the auxiliary battery. Should I attach the busbar to the "out" terminal instead?
Many thanks @MarkHThe Smartpass will kill the load when it reaches 11.5V whereas using the battery direct will drop it to dead flat (which can damage the battery). Ctek are saying you might want the UHF is still work below 11.5V as you might see it as a higher priority (emegencies) than say a fridge. I'd go to the sevice battery if the dashcam has a time out setting or voltage cutoff. My Blackvue 750 dual can be set to switch off after so many hours via the App, which I do.
Has someone started that thread?Hi - I am also waiting to install a D250SE and would love to check how the wiring is done given we already have the 120 installed - for instance ?extra fuses required in the 250 cabling. Perhaps we should start a new thread to share the experience of adding a 250 as I am sure a few will be doing it.
If I connect the Projecta DC-DC charger 12V signal wire to an ignition-controlled 12V fuse, is that likely to impact the Smartpass 120s operation even though the alternator will be responding to the Projecta charger, not the Smartpass... or will all (3) batteries benefit from the altered activity of the smart alternator ?
