For what it's worth, a solid blow from the palm of your hand works great to unstick the button. A block of wood and a mallet work great to adjust the "hole" alignment so the button doesn't come into contact with it
Yes..I have had three doors with this problem, front ,back and tailgate. You think you've shut the door and locked it when actually you have not..I now visually check and recheck . WD40 seems to work when sprayed into the door button circumference.Is anyone else experiencing a sticking drivers door external door button which prevents the door from
Latching into the B post door latch? Spray grease temporarily sorts it but it’s back in a couple of days?
Yes! Just started to happen…..Is anyone else experiencing a sticking drivers door external door button which prevents the door from
The advantage of not having dirt roads in the UK!Have the same problem on rear doors and boot door too.
Now using graphite style [ copperslip] grease weekly and so far so good.
Same here, drivers door, comes and goes, will raise it with dealer. ThanksIs anyone else experiencing a sticking drivers door external door button which prevents the door from
Mine have been like it from new, 4 weeks now, although the drivers door and passenger door do appear to be " loosening" off with use.i took delivery in LA/USA on 12/23/23, same problem with passenger front door, so still a continuing problem. same thing dealer (major local dealer) said they are aware of it.
Same with mine but silicone spray seems to do the trick for now.Mine have been like it from new, 4 weeks now, although the drivers door and passenger door do appear to be " loosening" off with use.
I would imagine the "surround" needs to be adjusted... a piece of wood (timber for you folks) and a mallet will fix it in one or two blows.I have one rear near side door that has started constantly sticking, repeatedly, regardless of graphite lube application.
Using a fold a way umbrella for exactly that task.I would imagine the "surround" needs to be adjusted... a piece of wood (timber for you folks) and a mallet will fix it in one or two blows.
Same. Is rear behind driver.I have one rear near side door that has started constantly sticking, repeatedly, regardless of graphite lube application.
Hopefully Grenadier will come up with a proper and substantial solution which will do a world of good to all owners and the brand. This problem exist without doors being exposed to rain or dirt and applying lubricant can not be a remedy.
