- Local time
- 11:13 AM
- Joined
- Jul 27, 2022
- Messages
- 6,005
So I thought I'd check this out for myself today.I don't think the rock sliders are ideal for jacking with a hilift. They seem too flush with the bodywork. There's always a degree of wobble in the foot of a hilift where the baseplate meets the lifting beam and once a wheel is lifted it's easy for it to move a little off vertical and lean in. It looks too easy to damage a door, the margins just don't seem to be there.
I started with just using the first concave section of the jack lip, to give maximum standoff. Note: I'd never actually use just this portion of the toe in a real jacking situation.
It's not a perfect match for the section of the rock slider tube, but it does work:
But I was pleasantly surprised at the standoff this gave:
There's certainly plenty of room to get more of the toe under the slider:
I then moved to the second "step" in the toe and measured the standoff at the utility belt:
Which then made me think that a packing piece of wood/plastic/rubber attached to the utility belt would be an ideal way to ensure any jack mishap would not cause a costly scratch/dent/hole in the door. The section could be kept separately and just attached in seconds at whatever corner needed lifting:
As an aside, I can confirm that the anti tilt element of the alarm works well, setting the alarm off before all the travel in the suspension had been taken up.
