Side steps versus Rock sliders
Yeah, haven’t ordered them but thinking I might want to be able to get a hi-lift under them… for recovery rather than tyre change of course.
I recall reading, hearing seeing something that said the step could be used as a jacking point.
Probably on here so maybe use the search function in the top right
Yeah, thinking that might be sketchy for recovery as there’s nothing to brace the top of the jack against. I’ve got one of those ARB hydraulic jobs and jack point permitting you can snug it right up against the body work so it‘s not going to rock off balance and damage your door or take a finger etc. Exhaust jack those would be the go though.
Came across a Mongolian farmer who’d tipped his UAZ onto it’s side (to rebuild the suspension) using a couple of yaks. We thought we’d come across a rollover and spilled out all ‘Thunderbirds are GO!’. Bucolic scene for context:
It's here @10:08 :
It's in the configurator:
But then again, it was also on the Ineos website as a step, which it clearly isn't:
I think they refer to the Rock Slider as "a handy step" and don't mean "The Step" offered in the configurator.
I do however think that both have the same mounting points and bolts and should thus have the same strength as far as mounting is concerned.
No chance that the rock sliders I saw at Firle could be used safely as a step. Yes with climbing shoes you could get the toe point on but boots, you'd be skimming your knees as soon as try. Think they have misled people with the above.
I'm not crazy about either option really. I'd like something that could serve as a step (I'm not the tallest guy in the world) but I would prefer steps that aren't that far from the sill.
Those ARB hydraulic jacks are nice bits of kit. But at £870 in the U.K. I won’t be getting one any time soon. Just hope I don’t have to jack the vehicle up too many times. Old Hi-lift jack for me !
None of you Neanderthals open your wife’s door and assist her getting in ;)
It comes as a surprise to me that off all the crack-pot plans and ideas I had in my 20s, the plan to marry the smartest, prettiest, tallest girl I could get to talk to me worked out SPLENDIDLY well.
My wife who is not very tall wants what she calls pigmy steps so she can climb in with short legs
My issue is that they look to hang very low and would no doubt be an issue on rough tracks. would the rock sliders give any advantage to my short legged lovely wife. Hard to tell without seeing them in the flesh
i would guess not. But any help with my problem would be appreciated
cheers Pete
I asked the Ineoes people at the 4x4 show and they said can’t really step on the sliders. I have had a good look at the side runners and have been pretty impressed. They are very solid and bolted to the chassis, nothing like the tinfoil sidesteps that come OEM with most new vehicles. They look like they hang low but really they aren’t lower than other stuff under the car and would likely provide a fair amount of protection for the body from rocks and sticks. They don’t replace sliders entirely because there isnt a bar running the full
Length under the sill but a a partner pleasing compromise they are not bad at all. I have ordered them, hopefully at some stage in the future someone will make a nice aftermarket combination slider/step and I will probably change out then.
I also read in the spec that you can use the rock sliders for lifting the IG if you need to say change a wheel, there was no mention of this for the side steps.
I did hear you can with the side runners but haven’t seen anything official on that.
@Chocki yeah I read the same thing. Rock sliders can be used with a high lift jack. hopefully IG have provided a slightly better jack than the long running opposition ?
It has a hydraulic bottle jack, looks nice and beefy.
If my wife ever struggles with getting into the vehicle I'll enrol her in a Tactical step class.
High steps. Must be good for flexibility and strength eh?
Or she can just practise on our stairs at home, 2-3 at a time!
This is the same one that Land Rover supplied in the Discovery. This one works very well.
They are a tough unit. I will be fitting a base plate into the storage compartment and my U shaped axle cradle as well.
To suit all those awkward angles and terrains one tends to meet.
My wife is not just a decoration in the Grenadier: she will drive it herself, even without me. So she has to learn to enter it on her own - and will probably call me a clown if I don't trust her to do so. ;-)
I always carry a thick poly Kitchen cutting board. Useful for cooking, cleaning fish and as a base plate for the jack if necessary.
