Side steps versus Rock sliders
I have seen where the jack is housed inside the rear of the IG. Has anyone sees 1) where the jack's arm is put away indie the car and 2) where the jack is fitted underneath the IG in order to raise the car?
I asked about the handle and tools, I believe there will be a tool roll that sits in the area between the Jack and the outer panel. Don’t know about the jacking points
Those ARB hydraulic jacks are nice bits of kit. But at £870 in the U.K. I won’t be getting one any time soon. Just hope I don’t have to jack the vehicle up too many times. Old Hi-lift jack for me !
I don't think the rock sliders are ideal for jacking with a hilift. They seem too flush with the bodywork. There's always a degree of wobble in the foot of a hilift where the baseplate meets the lifting beam and once a wheel is lifted it's easy for it to move a little off vertical and lean in. It looks too easy to damage a door, the margins just don't seem to be there.
This is the method I use to change a tyre when not perfect conditions for the bottle jack. Lift up by the wheel. Chock the axle then lower the jack .Change wheel then then jack up again to remove chocks or axle stand. 👍
This is clearly one of the downsides of a conventional farm jack. Normally the door panel arcs away from jack when lifting however, as you say, if the base plate slides or the wheels are inadequately chocked all bets are off.
Excellent video Tazzieman because he has so many great tips on how to solve outback travelling problems - changing wheels, jacking up cars, etc.
Also, "catching a croc" @ 43.30 is not for the faint hearted
Having said that - I'm not too sure how many people would travel as basically as he did back in the day!
When I was a boy I spent small amounts of money to enjoy living like a homeless person.
Nowadays it seems everyone travels 4 star - or 5 if you find a rockpool.
Talk about carrying everything - and 2 kitchen sinks!
Good for the economy.
And bad for personal experience and the nature!
Apparently this is a thing now, looking at the views, 4.5million:
If you forget to pack your jack , or lose it , this is the correct way Australians get out of trouble.
Go to 5:44
I've seen a this and a variant (in a military training manual of old) where the stump is just chained to the axle itself; never seen anyone demonstrate it though. (y)
Hope this helps there were other tools in roll like screwdriver and hex/torx keys
On the model I looked at the tool roll was under the driver's seat (RHD) attached with a fixed loop and buckle. Not sure if it's the same seat (passenger) for LHD vehicles though?
That's where I stuff some tools in my S1 Discovery. No electric motors or heaters to get in the way of utility!
