Scheduling First Visit and Warranty Work
Mountain4x4
9:10 AM
Albuquerque, NM, USA
About time for first oil change and dealer visit, here is what I got.
1. Busted Key fob, spring broke immediately.
2. Steering wheel error light appeared once ( apparently software glitch)
3. Check engine light never goes out, could also be software
4. Roof rack and awning been waiting for 6 months
5. Tire Pressure shows, blank screen and tire sensors have failed( updated)
6. HVAC makes a racket on high
7. Cruise control non-functional, likely related to check engine lights.
8. Praying for ADAS software update
9. Passenger Air Bag off line ( forgot that one)
Will check with wife later on final list. Hopefully goes better then this weeks visit to FORD where they denied a broken door lock because scratches on lock indicate someone tried to break in :rolleyes:
CrazyOldMan
10:10 AM
Wisconsin, USA
5. Lost contact with one TPS sensor
Did they give you an accessory credit or something? If not, I wouldn’t be waiting around for the RR rack and awning (#4) - there are better options available and you can get them pretty much right away
landmannnn
4:10 PM
My fan queirened down after a few months, just bedding in!
lagartoboy
10:10 AM
Texas
On the cruise control, it may be caused by the parking break being very slightly engaged- not noticeable and not enough to trigger the idiot light. Pull it up, then force it all the way down. That worked for me when my cruise control wasn’t working at delivery.
Global Grenadier 76
11:10 AM
If a check engine light is on, cruise will not work.
Global Grenadier 76
11:10 AM
Have you tried to open your NATO cap? Mine was locked up pretty good.
Old Salt
11:10 AM
Connecticut, USA
What is your build date and #. Looking to see if there are common issues with certain builds. I also wonder if some Dealers are better suited to sort some of these issues prior to delivery where others are not.
