I was hoping for that to happen!I would propose, if you agree @Rok_Dr , that your Exceedingly NOT Simplistic Manual supplement should be placed in the Resources of this forum! @Stu_Barnes , what do you think?
Thanks JeanI would propose, if you agree @Rok_Dr , that your Exceedingly NOT Simplistic Manual supplement should be placed in the Resources of this forum! @Stu_Barnes , what do you think?
Very reasonable and understanding. Thank you again for all you are doing!Thanks Jean
Not at this stage as it's a work in progress and managing updates is easier for me (and stu) by keeping it in this thread with a one drive link.
Once the document gets to a point where its stable and only needs a rare update then certainly worth considering.
Steve
in the fulness of time.I was hoping for that to happen!
Apologies @carpetman I'm not sure what happened there but the file was deleted from my one drive directory. I've re published it and locked it down so you can copy but not edit.Is anyone else having issues with this link? When I click it it goes into microsoft login loop, that ends with too many login attempts, try again later.
For this, many, many thanks.Since Christmas I’ve been slowly compiling an off-line document which I can print and put in my glove box that captures information missing from the owner’s manual and other useful bits and pieces.
I’ve now got it to a point where its ready to share with forum members. You can download the PDF using the following link:
https://1drv.ms/b/s!Av0mIsjCTYKCrYQXQiQwa2ekGa4yJw?e=XJm0HS
The forum has been a great source of information so thank you all for your efforts. Posts I’ve drawn information from are referenced (if you need further info) and members acknowledged in the document.
I’ll update the link in this post and post an alert in the thread when I update the document. Any feedback, corrections or even additions are welcome. Happy for you to share provided you make acknowledgement to this thread.
If you print it out either use an A5 page and shrink to fit or an A4 booklet in adobe reader print settings..
May you find it useful.
Steve
Any chance you could make it 3D and put it online /sUPDATED 3 June 2024. New Link Below. Refer to post #48 in this thread for changes.
I’ve now got it to a point where its ready to share with forum members. You can download the new PDF using the following link:
https://drive.google.com/file/d/1-EDl9zbw9ENhBw7XO0Swu09YZOZIGeIX/view?usp=sharing
Steve
Good pickups @MACS. Thank you, much appreciated. That Littelfuse pdf is also very useful.@Rok_Dr
Great work! Thanks. May I add some minor comments for the next update:
Page 10, 7.2. Pre-Fuse Box - It contains 125A Mega fuse, not "Mega Midi".
Appendix 1, fuse listing - "Interior Electrical Center"- Fuses should be numbered FI instead FL according to INEOS terminology.
Appendix 1, fuse listing - FI30 should be "Customer provision RHD footwell" not LHD
The problem with this is that it all wakes up when you open the doors, it also reawakes when reconnecting the battery. I wasn't aware of this when I added my CTEK charger cable but it didn't seem to cause any issues. But, it could also be that I'd had door open that long trying to remove plastic covers that it had gone to sleep?I went through the manual (except the path finder part), great work!
I liked also the "tire pressure table, I will print it and put it in my car for my next trip next month.
I have also a suggestion:
§12.2 the “3 minutes” sticker for disconnecting the batteries is only available in a private Group “Ineos Grenadier Owners Australia”.
Perhaps you can put a picture in your manual, but I had (a bad) one on my computer, copied from somewhere:
Thank you very much Steve. I have printed it out and after reading, its straight to the glovebox. You have managed to do what Ineos couldn't!UPDATED 3 June 2024. New Link Below. Refer to post #48 in this thread for changes.
Steve
