Recommended tools
Three of the best breakdown parts, electrical tape, cable ties and 3mm to 4mm fence/gardening wire you will surprise yourself how much these three items will get a car mobile again or use for camping with the assistance of a multipurpose tool like a Leatherman or a SOG.
Agreed I’ve used all three on my travels to get me out of a fix and some repairs lasted weeks until I could get to an Ineos dealer 😎
I've got spare standard valve stems but have found out about these emergency stems.
Not cheap, but the alternative might be a lot of effort.
View: https://youtu.be/wxmChHZ9W4Y?si=6o8jIoDCFtU0vTZe
Hello Tazzieman, my daughter had a valve failure on her car today. So I remembered your suggestion. A valve like that costs €20 here in Germany. But there seem to be different ones. Does anyone in the forum know the hole diameter of the valve in the 17" steel rims?
Oh, I just saw that the valve hole diameter is identical. The question still remains which one would you prefer?
The green card is a permanent valve, the red card is an emergency valve. I would probably use the Emergency valve, get the wheel valve replaced at a tire shop, then put the emergency valve in your tool kit.
Given my penchant for collecting old cars , one of these battery testers was overdue in my toolbox, and will be useful for the rest of my family and friends. Tried it out ; it works very well. Comprehensive information.
Went into Total Tools today chasing a thread gauge and came out with a set lo low profile torx bits. Just the thing for getting the battery trim panels removed.
Steve
Steve
We should just replace all these fancy little torx fittings with normal bolts 😊
Except it would cost more to buy all the bolts needed than the socket/bit sets 🙂
I've got far more than I need!
The legacy of owning multiple old cars.
Need one bolt - end up with a packet of 6
