Pics of 1.7" Eibach kit
This isn't exactly what you wanted but I thought I would throw this out anyway. This is without lift versus the 2.5" lift. Sorry the w/o lift is a bit underexposed. I'm about to put a 50+/- lb. bull bar on the front so it may come down a little in the front. But if I was doing it again, I might have gone with the 1.7" Between the lift and the taller tire my 60 yr old knees creak a bit getting in/out. These are 275/70-18 BFG K03s
View attachment 7864240View attachment 7864241
What size tires are these?
Eromanga is a tiny town in western Queensland Australia with a fantastic Dinosaur museum including a 60 metre long dinosaur called Cooper
Yep and the worst mobile coverage of any town I visited.
I also saw Monty, who is bigger than Cooper.
Does anyone know where you can get only the front 35mm (1.7") springs? That accomplishes the leveling I want, but minimizes the change in driveline angle.
I'm trying to decide between the 2.5" and 1.7" Eibach springs. Will be adding the 1.2" on the rear.
I'm used to an even level on my trucks, but don't mind some rake, either. Be great to see some pics of your 1.7" rigs - it'd be great to also know what wheel & tire size combos you're running.
Gracias!
Where did you find these? What was the brand and sku number? I cant find them anywhere
it is the Standard Pro Lift Kit from Eibach for Europe. Sku for the winch version is:
31-34-001-02-FA
Not sure if this is still relevant, but I just ordered the 1.7" front / 1.2" rear set. I should have it on in a couple weeks and can upload some photos. I will be pairing the lift with Owl Talon 17x8 et+30 wheels and 285/75r17 Toyo Open Country R/T Trail tires.
Look forward to seeing that. The exact setup I’m considering.
Where did you order them?
