OK4WD has them in stock.Where did you order them?
OK4wd.com. Shipped the same day, should be here Monday.Where did you order them?
Same as stock, 35s; I'm moderately confident that going to 37s will require fender (or at least flare) modifications)I'm thinking about doing the 1.7" + 1.2" combo
What size tire can you fit with that combo?
I have 33" tires on my stock truck without any problems
I've been reluctant to level it because I feel like the rake actually results in better visibility on the trail. I could be over-stating that, though.I've never levelled up a vehicle's factory rake. Is it just a cosmetic thing? Do you guys find any change in steering/ corner handling or hard braking?
Because removing rake is as American as apple pie.I've never levelled up a vehicle's factory rake. Is it just a cosmetic thing? Do you guys find any change in steering/ corner handling or hard braking?
Whilst removing downforce!But in my pilot’s mind, I would imagine removing some rake helps some aerodynamic drag along the roof line.
But if you raised the front by 4", imagine the rock step you could conquer!I've been reluctant to level it because I feel like the rake actually results in better visibility on the trail. I could be over-stating that, though.
A truly American trend... In my opinion, it is founded in the fact that we as a country love to buy vehicles and not use them for their purpose... Like buying 1 ton pickups and never putting anything in the bed; enter the "leveling kit". This could easily be avoided if you carried anywhere close to the 1800kg payload in the bed of those trucksI've never levelled up a vehicle's factory rake. Is it just a cosmetic thing? Do you guys find any change in steering/ corner handling or hard braking?
But much better than this trendA truly American trend... In my opinion, it is founded in the fact that we as a country love to buy vehicles and not use them for their purpose... Like buying 1 ton pickups and never putting anything in the bed; enter the "leveling kit". This could easily be avoided if you carried anywhere close to the 1800kg payload in the bed of those trucks
Thanks for this. I've been on the fence of 305's vs 315 70/17's Thinking I'll go 315 now.I just did this. The 1.7 fronts and 1.2 rears.
Stock 17” steel wheels.
Easily fit 285/75/17 KM3’s.
Could have fit 35x12.5x17 with minimal plastic trimming. Didn’t want to do bigger offset wheels, likely would fit then. Also unsure of the articulation range but the 35 didn’t look like it was “stuffed” up in there.
Happy with my outcome, I tow a lot and had to retain the rake so I wasn’t Carolina squatting.
Sure thing. I couldn’t find much info on this combo. This exact lift and stock wheels. Seems like most folks swap the wheels out.Thanks for this. I've been on the fence of 305's vs 315 70/17's Thinking I'll go 315 now.
