Oil change using extractor (vacuum)
anand
10:39 AM
Maryland
Why would you do that?
For other vehicles, it is so you don't need to get under them or lay on the ground... I use this method on our Sprinter (and in the past a few other vehicles where the filter was on top)
pmatusov
7:39 AM
San Diego, CA, USA
I understand the need and desire for vehicles that don't have the insanely easy access to the drain plug (as easy as on old Land Rovers), but not for the Grenadier.
Global Grenadier 76
10:39 AM
It's far less messy too. Plus, if I'm not mistaken, some vehicles no longer have drain plugs and can only be serviced with the vacuum setup.
anand
10:39 AM
Maryland
Definitely less messy... I've gotten pretty good at lining up a drain pan after years of doing it, but just letting the extractor suck it all out is much easier
Norb-TX
9:39 AM
Houston
Mercedes and some other brands designed their cars to be changed this way. People even did a comparison vs drain and it was the same or even more oil extracted. That's why they took the effort to put the filter up top. Disappointingly the Gren doesn't have this, for a safari truck, not having a dip stick is questionable.
9:39 AM
Inlet Beach, FL, USA
For my Range Rover, the oil can be extracted via inserting the tube in oil fill well after removing the oil filler cap (this vehicle does not have a dip stick either). As mentioned in other responses, extraction is a common method used on Mercedes and other vehicles and tends to extract the same or more oil. I was just wondering if anyone had tried this yet on the Grenadier and if there were any issues (especially if not all of the oil can be extracted).
Global Grenadier 76
10:39 AM
Interesting - I always thought those systems used the dipstick opening. Might be worth poking around BMW or Supra forums since they use the B58 as well.
Old Salt
10:39 AM
Connecticut, USA
I am a bit old school and prefer a dip stick for measurement and to drain the oil out the drain plug. Oil level sensors can fail, a dip stick, well not so much. Draining oil out the drain plug will help remove any built up sediment and sludge. The shallow pan in the front and well in the rear is going to concentrate any of that sludge right near the oil level sensor. Having said that, with the synthetic oil most drivers are not going to see a lot of build up especially if they are driving in benign environments. I think most designs are a product of the times where 99% of drivers don’t even know how to check their oil levels let alone crawl under their cars to change the oil.
I am not anywhere close to my first oil change does anyone know if the drain plug is fitted with a magnet? If not is there an aftermarket plug / magnet out there?
Global Grenadier 76
10:39 AM
The drain plus is not magnetic.
