I had a follow-up chat with an Ineos Rep who spoke to the technical team. There is ZERO change to the steering system or components between '23 and '24 vehicles. So while exciting to think of - not going to see it.
Yeah, and Ive gone back and forth on that whole "pre-production" thing.They are not "production" technically; they are still considered some sort of pre-production hybrid, and are of varying degrees of "production" level (some have bits and bobs that others do not, that make then more like a MY23 or more like a MY24, but are truly neither one). This applies to the Ineos corporate demos, dealer demos (which are still owned by Ineos), and media vehicles
Info I can source also suggests there is no hardware change on steering for cars, including 23.5 and 24. Does not preclude anything software, Im not sufficiently across electric/jydraulic combo to know if that is a possibility. You’d probably like to think not, unless it is burned onto a bombproof chip… even then… but happy to learn something from anyone who knows?I had a follow-up chat with an Ineos Rep who spoke to the technical team. There is ZERO change to the steering system or components between '23 and '24 vehicles. So while exciting to think of - not going to see it.
I did see something here that the software updates changed the pressure in the steering system which made it feel tighter. Think a gentleman from the UK brought that upBump
Wondering if anyone has additional info since the last post?
How can an owner identify a version 23.5?I think the change is the 23.5 version. I guess that the non prototype cars in the USA will already have the change. But no idea for sure.
Same as one I've talk to this vendor on - but located in WA. I think the key though is to see how we like the vehicle first before tweaking - so this is perhaps a 'back of the pocket' sanity pill.
My larger concern is that the steering stabilizer has less ground clearance than the rest of the steering components. My fear is that it is only a matter of time until it gets bashed or broken. Not really sure why it is mounted in the position that it currently resides in.Same as one I've talk to this vendor on - but located in WA. I think the key though is to see how we like the vehicle first before tweaking - so this is perhaps a 'back of the pocket' sanity pill.
Steering Solutions - Reflex - Roadmaster Inc.
www.roadmasterinc.com
They broke it off-roading in the Red Noland prototype and said its fine without it.My larger concern is that the steering stabilizer has less ground clearance than the rest of the steering components. My fear is that it is only a matter of time until it gets bashed or broken. Not really sure why it is mounted in the position that it currently resides in.
They currently do not make the dampener for a Grenadier - but will when they get one for fitment. The ground clearance they know is a requirement. I’ve been talking with the head of R&D about it.My larger concern is that the steering stabilizer has less ground clearance than the rest of the steering components. My fear is that it is only a matter of time until it gets bashed or broken. Not really sure why it is mounted in the position that it currently resides in.
There is no doubt it is not in a good spot. The saving grace is that it’s pretty easy to remove in the field and it won’t cripple the car, it will still be driveable.My larger concern is that the steering stabilizer has less ground clearance than the rest of the steering components. My fear is that it is only a matter of time until it gets bashed or broken. Not really sure why it is mounted in the position that it currently resides in.
They don’t ship this one to USA
If it’s a problem they a relocation kit will solve it.You can literally install it in 15 mins and remove it even easier - all bolt on/off in the field
HI Douggie, You might give some consideration to the "Exact Center Steering Stabilzer from Road Master. Both @YellowLab and I have been speaking to the company and they are going to support the Grenadier once a Forum member brings their Grenaider over to them. They are based in Washington State in the USA. They have a patent on this Return to Center Steering Stabilizer which is very unique and sounds perfect for the Grenadier. Not only is it a stabilizer, it also has a return to center function built in.Using a custom made double ended bolt that is used very successfully doing a similar mod on Jeep JK/JL, I am looking at a Bilstein steering damper mounted above, deleting the welded mount below once testing for clearances are confirmed. Can advise late in January when the work is complete
Illustrated here without the bolt (there is a possible clearance issue to be checked through all suspension travel range)
I looked to see where they are to see if it would be worth making a day of being a guinea pig. They're in Vancouver, WA, which might more easily be doable for one of the Portland area members.based in Washington State in the USA.
