Calm down. It could cost 10.000 € and you would still not need it in EuropeThis fuel tank will be around 2000€, I guess.![]()
I did think so. But your smiley looked so horrified...I don't want nor do I need it. And I don't have a such a playmobil "Defender".
I just guessed a price ...
It works suprisingly well with the bike carrier we use. Its rated for 50 kg only buth the System is the same. The only connection is the hitch ball.If this gargo box rests on the hitch, how is it kept level? Just clamping it tight on the hitch ball doesn't seem to be a trustworthy solution to me.
Does it rest left and right on the bumper as well?
PAKMULE installs into a 2″ square receiver opening...If this gargo box rests on the hitch, how is it kept level? Just clamping it tight on the hitch ball doesn't seem to be a trustworthy solution to me.
The concern is that there may be no room in the diesel version.Hi guys,
Top Cat here. I regularly travel in the Australian bush in my D2 and D4 and both carry a 110litre and the standard disco fuel tanks. The fuel loading is the main concern I have for my ordered Grenadier.
I will be keen to see under the vehicle to see if a spot has been left for a second tank. Carrying fuel on the rear of the vehicle is not a good idea here and only properly mounted metal cans are used.
Hi guys,
Do you contact the Kunawarritji store to book in your supply?Don't panic you do not require such a large fuel range for the Canning stock route.CSR
Fuel available at well 33.
Brown Davis or Long Ranger will soon come up with an appropriate tank.
