Leaking Windshield Washer Tank
arcteryx33
4:54 AM
Philly
4 weeks of ownership and I continue to find a small puddle under my front left bumper which appears to be washer fluid. Anyone experience this yet? I assuming it is a simple connection issue on one of the lines or tank but wanted to ping the group before digging in.
I just dropped off my Grenny at the dealer to have this fixed plus the AC recharge.
They've had some IGs in for this. Someone did mention about a loose connection, so it must be the same issue.
One easy way to trace a leaking windshield washer fluid system is to fill with the available blue-dyed washer fluid type. The blue additive will collect and dry along the leak trace and make it a lot easier to rule out if it’s something else.
Got a call from the dealer and the leak is coming from one of the hoses connected to the washer fluid pump.
They ordered the parts which will take 10-15 days so will need to go back for part replacement.
Had the AC recharged too. Will find out tomorrow if the AC does not act up again.
I have the leak as well but have not taken it to the dealer yet.
