Leaking - Multiple Areas
Hi all,
Thanks for sharing the information about the various leaks, especially around the Safari Window and front-facing camera area.
I haven’t experienced any leaks yet, primarily because my Grenadier hasn’t been exposed to rain. However, I’m anticipating it since this seems to be a common issue.
I’m curious—if this is a known problem, why can’t Ineos or the dealers address it preemptively, perhaps through a recall?
Since I haven’t encountered this issue yet, I’m unsure how to prevent it before it potentially causes interior damage. I’d appreciate any thoughts or suggestions on this.
For reference, I came across a YouTube video discussing the Safari Window leak:
View: https://youtu.be/-yWt3vsQAW8?si=L9Q_0iuEz0V9urWN
Thanks in advance!
Hi all,
Thanks in advance!
See this TSB
Seems to be fix only when an issue is noted.
See this TSB
thanks for letting me know.
Its a bummer that nothing will be done unless you already have a problem.
Left hand drive, heavy rain last night, lots of water rushes out when opening driver door - LOTS more water in the driver footwell, area behind pedal completely full of water. Not great. What's the fix???
"lots" of water possibly indicates safari window leak... The "bootwash" provided by the door seals traps water between the two seals, but specifically doesn't allow it into the vehicle
No safari windows. Somehow the bootwash function is letting water into the footwell. Can't see how just yet.
I was so happy when I went through my first thunderstorm downpour and the doors didn't store the water and the safari windows didn't leak. I have two other things on the IG issues bingo card and 1 that I haven't seen anyone else mention though.
