Oh my - how does stuff like this leave a production factory as "acceptable"??I had exactly the same with windscreen top seal. Dealers filled and sealed it.
Issue with the safari window seal too??
It is fairly high up so wouldn’t be a place most of us would see or normally check. A quick look might save water ingress or trapped water and corrosion issues. And it is an easy fix.Good to know. Perhaps we should all inspect that area.
I have a hunch it's not your screen, as they are bonded and that is a trim panel coming apart. My first stop would be the sunroof(s) check for clear drains on both sides. if it was the screen it would be leaking down the sides (A pillar) as well.
I’m pretty sure it’s the screen. The only place the screen is coming off is in the center near the camera which is where the water appears to be leaking from. I’ve had a couple others reach out who had the same issue. It’s not leaking down the sides because the screen is fine on the sides. It’s localized to a small section in the middle. With that being said, I’m gonna have the dealer look at it and confirm.I have a hunch it's not your screen, as they are bonded and that is a trim panel coming apart. My first stop would be the sunroof(s) check for clear drains on both sides. if it was the screen it would be leaking down the sides (A pillar) as well.
Look forward to hearing what Triad has to say!I’m pretty sure it’s the screen. The only place the screen is coming off is in the center near the camera which is where the water appears to be leaking from. I’ve had a couple others reach out who had the same issue. It’s not leaking down the sides because the screen is fine on the sides. It’s localized to a small section in the middle. With that being said, I’m gonna have the dealer look at it and confirm.
They were supposed to call me first thing Monday morning and I haven’t heard from them. I’ve followed up multiple times.Look forward to hearing what Triad has to say!
Agree Jean. Had the same topic and since the dealer fixed the sealing and „re-adjusted“ it that problem was solved.Safari roof gasket! 99% sure. Had it myself.
A well known problem at Ineos!
[edited] See my problem here: https://www.theineosforum.com/threads/water-leak-at-safari-roof.12412757/
Is the vehicle at Triad currently?They were supposed to call me first thing Monday morning and I haven’t heard from them. I’ve followed up multiple times.
Nope, still haven’t heard from themIs the vehicle at Triad currently?
I spoke to dealer and they should have the parts later this week to seal safari roof and/or the rubber piece along the windshield (if that is what is causing it). I haven’t had any leaking since I put some tape along rubber piece along windshield. With that being said, I’d like to put some tape along the safari roof just in case I’m wrong. Where should I put it to prevent leaking? Just along the edges?Agree Jean. Had the same topic and since the dealer fixed the sealing and „re-adjusted“ it that problem was solved.
Had the water coming in at the same spots like you @bjsheeri .
@anandI had exactly the same with windscreen top seal. Dealers filled and sealed it.
yes, along the edges.I spoke to dealer and they should have the parts later this week to seal safari roof and/or the rubber piece along the windshield (if that is what is causing it). I haven’t had any leaking since I put some tape along rubber piece along windshield. With that being said, I’d like to put some tape along the safari roof just in case I’m wrong. Where should I put it to prevent leaking? Just along the edges?
@Jean Mercier
What type of tape did you use? I have the same issue and want temp fix until I can get to the dealer.
I’ve been using black electrical tape but the dealer recommended painters tape. With that being said, I was still having some leaking when I taped the windshield so I also taped the safari sunroofs. Haven’t had a leak since then.What type of tape did you use? I have the same issue and want temp fix until I can get to the dealer.
Thanks.
This is my universal stop-gap tape. Matches every body color.What type of tape did you use? I have the same issue and want temp fix until I can get to the dealer.
Thanks.
This won’t hurt the paint?
Not at all. In fact, let's say you left your sunroof taped closed for two months - it will still peel right off! Right now I have it on my door sills to prevent scuffing.This won’t hurt the paint?
Thanks very much!
Yup. My rubber wasn’t touching and I have a couple drops below the forward camera box. I’m getting multiple warnings for items handled by the camera so I expect the electronics in there to be toast.
