Got it. So, the problem must still be the safari window then...From what I've been told that piece isn't a seal, it is just a trim piece. The urethane that adheres the windshield is the seal itself
Hi all,
Thanks for sharing the information about the various leaks, especially around the Safari Window and front-facing camera area.
I haven’t experienced any leaks yet, primarily because my Grenadier hasn’t been exposed to rain. However, I’m anticipating it since this seems to be a common issue.
I’m curious—if this is a known problem, why can’t Ineos or the dealers address it preemptively, perhaps through a recall?
Since I haven’t encountered this issue yet, I’m unsure how to prevent it before it potentially causes interior damage. I’d appreciate any thoughts or suggestions on this.
For reference, I came across a YouTube video discussing the Safari Window leak:
View: https://youtu.be/-yWt3vsQAW8?si=L9Q_0iuEz0V9urWN
Thanks in advance!
thanks for letting me know.Leaking Sunroof Seals
A problem has occurred on a small number of the affected vehicles where water may leak past the Sunroof Seal and into the vehicle Click on the download button for more details.www.theineosforum.com
See this TSB
Seems to be fix only when an issue is noted.
"lots" of water possibly indicates safari window leak... The "bootwash" provided by the door seals traps water between the two seals, but specifically doesn't allow it into the vehicleLeft hand drive, heavy rain last night, lots of water rushes out when opening driver door - LOTS more water in the driver footwell, area behind pedal completely full of water. Not great. What's the fix???
No safari windows. Somehow the bootwash function is letting water into the footwell. Can't see how just yet."lots" of water possibly indicates safari window leak... The "bootwash" provided by the door seals traps water between the two seals, but specifically doesn't allow it into the vehicle
You just need to cut small holes in the outer door seals to let the water outNo safari windows. Somehow the bootwash function is letting water into the footwell. Can't see how just yet.
Awesome. Thank you.You just need to cut small holes in the outer door seals to let the water out
