- Local time
- 8:38 PM
- Joined
- Sep 30, 2021
- Messages
- 423
A suspension lift definitely raises ground clearance, just not on a straight axle vehicle. The front of that Hilux is 2 inches higher with a lift. For the Grenny, not so much.
Or some nice portals...and from Carraro's own marketing literature:More ground clearance below the differentials or the axles in general can only be achieved with a larger tire diameter.
It's worth noting that if people are referencing the Grenadier, then the Ineos method of measuring ground clearance should perhaps be used.A 2 inch suspension lift 100% lifts the differential in a IFS or IRS setup. If the pumpkin on a straight axle vehicle is the lowest part of a vehicle then no, it won't change that. But if the front crossmember or skid plate is the lowest part then a lift will raise that.
That's not an unreasonable view, and my preference for how it's measured as per my portal axle post.This sort of circular debate can be overheard in any typical Aussie pub/Sunday session. I’m with @emax on the view that it’s the Marketing types that are to blame, noting that design standards also pointedly differ.
https://unsealed4x4.com.au/busted-the-truth-about-4x4-ground-clearances-and-manufacturer-claims/
Not sure if you were referring to these guys?If aftermarket R&Pâs become available??
Not sure how the orange will look on a green IG but would have looked fantastic on my G4 Disco.
