Lamin-X film for fogs
Chadd7
3:01 PM
NJ, USA
I just put on some yellow Lamin-X precut film on my fogs. Very easy installation (dry method) and very high quality product. It’s thick and easy to work with even on our convex fog lamps. Just make sure you clean with alcohol thoroughly and center them properly. No air bubbles. And they apparently have a 20% sale going on now.
Looks great! I just did mine but I had ordered a larger film size which made it harder to work with. I had to use the “wet” method, to maneuver under the trim. That left me with a few small bubbles to work out.
I might reorder and reattempt with the 5”.
Thanks. This thicker gel-like material is definitely harder to cut. Even the little tabs on the precut round ones gave me some trouble. You may not need to redo yours. I read somewhere that the material breathes ever so slightly, so air bubbles will work their way out. Maybe use a squeegee and slight heat from a hair dryer to try to work out the bubbles before redoing?
Yeah, I’ll give it a bit of time to settle down and see how it does. I’m in the obsessing about it phase right now 😁.
@Chadd7 - How is this film holding up?
Really cool, cheap mod! I’ll be doing this as upgrading the grill lights is way down my priority list.
So looks like the 5" film is not large enough to cover the aux lights? I have a ring of uncovered light surface all around.
I have a slight ring as well but not but maybe 0.1 inches all around. Not enough to order the next size up
