Lamin-X film for fogs
Chadd7
9:37 AM
NJ, USA
I just put on some yellow Lamin-X precut film on my fogs. Very easy installation (dry method) and very high quality product. It’s thick and easy to work with even on our convex fog lamps. Just make sure you clean with alcohol thoroughly and center them properly. No air bubbles. And they apparently have a 20% sale going on now.
Kyabmo1
9:37 AM
Philly
Looks great! I just did mine but I had ordered a larger film size which made it harder to work with. I had to use the “wet” method, to maneuver under the trim. That left me with a few small bubbles to work out.
I might reorder and reattempt with the 5”.
Chadd7
9:37 AM
NJ, USA
Thanks. This thicker gel-like material is definitely harder to cut. Even the little tabs on the precut round ones gave me some trouble. You may not need to redo yours. I read somewhere that the material breathes ever so slightly, so air bubbles will work their way out. Maybe use a squeegee and slight heat from a hair dryer to try to work out the bubbles before redoing?
